Question about Refrigerators
Trying to troubleshoot my dometic rv fridge, trying to bypass thermal fuse. Any help?
Posted by thomas wellcome on
Jim Goldsmith
  • 2,005 Answers
For testing purposes only: just use a jumper wire with alligator clips on each end radioshack sells them
Posted on Oct 31, 2013
Dometic RV fridge will not run. No lights on the panel at all. Was running fine and then went out and will not come back on. We replaced the circuit board and still nothing. Please help.
You need to ensure you have 12V going to the fridge. Also insure you have 12V on both sides of the terminal block in which the 12V connects to. They will sometime corode. That is more then likely your problem. If you do not have 12V then you must check fuses at you fuse panel/converter in the RV itself. If you do have 12V going to the fridge then you must check the fuses in the new board that you installed. You can give us a call if you would like. We are Arcticold Refrigeration, we would gladly assist you. 1-888-782-6665 our web site is ArctiCold Refrigeration We keep it cold e65afc3a-64f6-4e84-bc75-990bdde64ddf.jpg
Mar 07, 2014 | Dometic RM2652 Refrigerator
I have a dometic dm2652 rv fridge. its new and is
The DM2652 comes with an optional cooling fan to help with cooling the amonia. The fan cycles on and off as required as it has a tempeature sensor (thermistor). We turn ours off at night by removing the inline fuse (glass tube fuse 3 amp) located in your outside acces panel. The fuse is located in a black fuse holder with a re wire connecting both sides.
Jun 06, 2010 | Dometic RM2652 Refrigerator
Our Dometic Americana in our RV is too cold and is freezing everything. We have had the thermal coupler replaced to no avail. Can you help?
just tried moving the temp sensor closer to the "fins" in the fridge part...we'll let you know if it works. The sensor is placed in a plastic sleeve that holds it to the fins. I have moved it so the tip of the sensor wire touches the end fin.....
Jan 17, 2010 | Dometic Refrigerators
My dometic duo therm brisk air RV a/c unit is not cooling the RV
I had the sam problem, took the thermostat cover off and tightend and refastend the wires, so far so god
Oct 27, 2009 | Dometic Rooftop RV Air Conditioner
Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Oct 23, 2009 | Dometic RM2652 Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
thanks
Jul 09, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
160 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
