Replace the water inlet valve to the unit. The valve is not closing completely after the water is called for. By replacing the valve should solve this issue.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: no water for ice maker
make sure wire is in down position this is like the on and wire up is off
SOURCE: Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker. Remove the icemaker and make sure that there is no ice buildup other than in the cube slots. Also make sure that the fill tube is clear of any ice obstruction.
SOURCE: LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice. If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
