I want to convert this heater to natural gas. Raypak 266K BTU Digital Propane Pool Heater - P-R266A-EP-C - 009225. What parts do I need? Can I use a convertion kit for the gas valve?
check your gas pressure most houses have too small gas meters add all gas powered appliances give the number to the gas company they probably will up grade yuor meter to a larger one this should take care of your problem
This issue sounds tricky. I recommend you call the Raypak technical support line at
800-947-2975 or 800-627-2975 and they should be able to help you figure
this issue out. I hope this helps.
