Question about Acme 5001 Supreme Juicerator Juice Extractor
How do I remove the top base that spins and has the vanes on bottom for cooling? the bottom of the cooling vanes are touching the cover below the vanes.,. I cleaned out the juice but it drags .... if I could take it off I'd sand down the cooling vanes a bit....
Posted by Roger Headings on
My lid doesn't seem to fit properly. When I put the top on to cover the screen, it doesn't seem to fit together properly-- the bottom of the chute that you throw the fruit and veggies down butts right up...
Is this a new cover? There is an adjustment. On the bottom of the machine, dead center,
there is an adjustment screw with a locking nut. Unlock the nut and the turn the screw
counter clockwise, this will lower the motor shaft and consequently the blade. Once you
have clearance and install the cover, turn the screw clockwise until the blade contacts the
chute, back it off a half turn and lock her down. This will establish the correct gap between
the chute and blade. Also if your chute is ever chipped or scored by the blade because
of excessive vibration, you can file the chute level and readjust the gap.
Mar 13, 2011 | Omega 1000 Juice Extractor
I need to remove the parts for washing How I do this?
Things You'll Need:
  • Soft-bristled brush
  • Stiff-bristled brush
  • Dishwasher (optional)
  • Mild detergent
  • Lint-free microfiber cloths
  1. Unplug your Acme 6001 Juicer. Carry it to a countertop near your kitchen sink.
  2. Remove the pusher and cover, and set the pieces in a sink. Unscrew the clutch, remove it and set it in the sink. Remove the cutter blade, strainer basket and juice bowl, and place the pieces in the sink.
  3. Discard or remove and store any pulp that you find in the strainer basket. When you're finished, rinse the remaining fruit and vegetable pulp and juice from the pieces under cool, running water. Dislodge hard-to-remove pulp from the cutter blade and strainer basket with a soft-bristled brush or with a stiff-bristled brush if necessary.
  4. Wash the pieces in a dishwasher or by hand. To wash in a dishwasher, place the stainless steel pieces in the lower rack and the plastic in the top rack and wash on a normal cycle with other kitchenware. To wash by hand, fill the sink with warm water and a few drops of mild detergent and wash with a lint-free microfiber cloth.
  5. Run the pieces through the rinse cycle in your dishwasher or rinse under running tap water by hand. Air or wipe dry the pieces.
  6. Wipe the base with a slightly soapy cloth. Rinse with a damp cloth and wipe dry. Reassemble your juicer by returning the pieces to the base in reverse order.
     for a visual:http://www.youtube.com/watch?v=alumocbDHg4
     "DON'T FORGET TO VOTE PLZ"
Jan 28, 2011 | Acme 6001 Juice Extractor
How do you get the latch arm back in. The bottom is easy but how do you snap the top????
Is this an older juicer and a new latch arm? Surprised you were able to snap it into the base.
If your problem is latching it down because it's a little too snug, file the upper tip a little to
increase the tolerance. Do it to a point where the latch arm will easily slip over the lip of the
cover and then latch it down.
Jan 11, 2011 | Omega 1000 Juice Extractor
I got the latch arms for my omega 1000 juicer but only the bottom goes in how do i get top part in
With some difficulty. Sometimes replacement latch arms are not an exact fit for
older models. You may have to file them down a bit so they will snap in place.
Also make sure the fit at the cover is not too snug or else the arm will break again.
Removing the 4 screws on the bottom and separating the base will give you a better
view on what has to be done.
Aug 18, 2010 | Omega 1000 Juice Extractor
My Acme supreme juicerator #6001 trips off several times before I can complete the process of juicing in order to get an 8oz. glass of juice. The motor spins smoothly, no vibration at all.
There is a reset button on the bottom of the
juicer. You will have to separate the base
by removing the 4 bottom screws and adjust
the sensitivity of the reset button turning the
small screw on it. Sorry, but forgot which
direction increases or decreases this. Had
to do it on my 21 year old Acme because of
the same problem.
Apr 22, 2010 | Acme 6001 Juice Extractor
Do not know how to remove basket
(1) Remove the food plunger and top cover; (2) unscrew the 3 screws from the blade/cutter plate and lift it off its base; (3) Unscrew the plastic base COUNTERWISE and lift it off of the center spindle; (4) Now you can remove the basket and juice bowl for cleaning.
To reassemble, reverse the process.
Dec 29, 2009 | Salton JM411 Juiceman II Elite Juicer
The blade keeps rubbing with the upper part of the machine
Make sure the orange blade is properly seated and screwed in place. Don't screw it too tight though. If it still touches the top cover, sand it off or file it off. Whatever the blade touches the white portion of the cover, file it off.
Oct 28, 2009 | Jack Lalanne Power Juicer 250 Watts
Trying to find a part for the power juicer CL-003 AP
The top white part connects to the motor. You have to buy the whole bottom part. It's not separate.
Jan 09, 2009 | Jack Lalanne Power Juicer 250 Watts
Breville JE95XL juicer
I used needle nose pliers, it took a bit of patience but I got the screws out. I think I might replace them with regular screws. My juicer does not run either. Let me know if you find the problem with yours.
Dec 26, 2008 | Breville JE95XL Juicer
Juice lady
On the stainless steel basket notice a notch cut out on the rim above the spout and an indentation on the back of the basket near the rim. The plastic ring must snap on to the steel basket before placing the assembly on the motor housing. If it does not snap on, it is not fully seated. After the ring is seated and on the motor base, push the basket on and spin it. Confirm that the basket clears the ring. Place the top cover with feed tube over the unit and lock the two clips down. This procedure should solve your problem.
May 13, 2008 | Juicelady JL500 Juice Extractor
Acme 5001 Supreme Juicerator Juice Extractor Logo
186 people viewed this question
Top Acme Juicers Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Acme Juicer Expert? Answer questions, earn points and help others
