This is either the door sensing switch (most likely) or a bad membrane switch [start switch] (that's what Panasonic calls it) on the touch pad. The contacts on the door sensing switch can be slightly contaminated and not read "zero ohms" to the control PCB. The control board thinks that the door is open and it will not allow the cook cycle to start.
SOURCE: control panel buttons on my
You have a failed
membrane keypad.
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
The best place to order
Panasonic parts is Tritronics. You can also call them at
866-779-5835.
If you would like to
have us do this for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your
model number) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: Panasonic Microwave SD697S quit cooking and has
HI, this will require the skilled hands of a qualified Panasonic tech. The damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible...
thank u
rate me!!!
SOURCE: Hi, I have a Panasonic
Hi Judith, I am Kelly
If this has a 1 year warranty it is time to make that call.
Otherwise see this link about H97 or H98 codes: http://www.applianceaid.com/micro_faultcodes.html#panasonic
There are a few things that can cause the problem, none of them cheap repairs. The Magnetron filament, Control board and Inverter are the top 3 other than a losse connection.
I tried running the Model number NN-SN9688 and it does not cross. See Panasonic link here: http://www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd?N=779832097&Ne=&No=0&Nr=12001&Ns=&Ntk=SupportSearch&URL=vSupportSearch&cmTag=true&catalogId=11017&storeId=15001&cm_sp=SiteSearch-_-SupportSearch-_-SupportHome&Ntt=NN-SN9688&x=28&y=20
I did not go to Panasonic Global and try other countries. I just did a USA search.
Thanks for choosing FixYa.
Kelly
