Question about Manitowoc SY0454A S Series Ice Maker Energy Star Half Cube 380 lb 24 hr Air Cooled
My Manitowoc Ice Maker Q 1800 does not stop producing ice, and we have to empty it constantly so that the motor doesn't burn
Posted by Hector D Valasis on
Marat Brikov
    Director Badge:
    Uploaded 100 video answers.
  • Manitowoc Master
  • 515 Answers
Ice bin thermostat is bad.
Posted on Aug 22, 2015
1 Related Answer
Joe Palazola
  • 124 Answers
SOURCE: manitowoc ice maker does not produce ice
If it doesn't run at all open the front panel and peer inside of the control box. See if there are any indicator lights on the control board lit or blinking. Check the plastic water curtain on the machine and make sure that the magnet is in place on the bottom right. Will need more information as to what lights are lit. Printed on the board next to each light is its corresponding function or response.
Posted on Dec 11, 2010
Manitowoc troubleshooting
Clean the condenser thoroughly, descale and sanitise the waterways inside.
Feb 15, 2014 | Manitowoc Ice SM-50A Undercounter Ice...
Icemaker runs constantly but never makes enough ice to shot off. Too much water spraying out and melting the ice. What to do? Have run through cleaner cycle several times. Disassembled and cleaned also.
Process of elimination. ... ice thickness sensor (adjust and clean).... water outlet bar with holes that runs down the ice maker plate (make sure all the holes are not clogged and point to correct angle to keep from splashing) check those 1st.. the other steps are more involve if you have refrigeration tools to check refrigerate level, etc.. let me know if this will help 1st
Oct 31, 2013 | Manitowoc SM50 Series Ice Maker
Ice maker stopped working, but used to work very well. During a course of a week, ice production kept slowing down to nothing. Test button on the side of the ice make unit does nothing. Unit is only a...
I had a similar problem with my Samsung fridge, my problem was the the ice holding unit had been taken out and not reinstalled correctly,
There is a rod on the rear of the tub and it has to be placed properly in the drive gear at the rear of the ice making housing so that it fits properly and smoothly.
If you still have a good water supply available at the door then the problem is probably what I just described, Good luck
Aug 27, 2011 | Samsung RF26VAB (25.5 cu. ft.)...
I have a model qd0452a manitowoc and it will not stop making ice
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Nov 17, 2010 | Manitowoc SY0454A S Series Ice Maker...
Manitowoc ice maker does not produce ice
Nov 11, 2010 | Manitowoc SY0454A S Series Ice Maker...
Freezer constantly produces ice buildup along the vents and fan blades inside are striking the ice buildup. Why wont the unit defrost? Also produces large chunks of ice from the ice maker during this time....
SAMSUNG REFRIGERATORS ARE KNOWN FOR DRAIN ISSUES., YOU NEED TO DETERMAN IF ITS FROST {DEFROST PROBLEM} OR ICE {drain issue} IF ITS ICE YOU SHOULD EMPTY IT AND UNPLUG OVERNIGHT WITH THE DOORS OPEN. IF FROST YOU SHOULD CALL FOR SERVICE.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 14, 2010 | Samsung RS2630SH Side by Side Refrigerator
Icemaker does not make ice
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker won't quit dispensing ice cubes don't have ice skates!
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repair
Dec 11, 2008 | Amana Refrigerators
Icemaker will not was dispense ice
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Manitowoc SY0454A S Series Ice Maker Energy Star Half Cube 380 lb 24 hr Air Cooled Logo
346 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
Marvin
Marvin
Dennis
john h
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
