Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
My toilet keeps filling on it's own - American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
Posted by Ross Bull on
rplant
    New Friend:
  • 22 Answers
Replace flapper. Use American Standard flapper for your unit.
Posted on Nov 11, 2013
Why would the jacuzzi perfecta toilet handle comes off and now won't fill, just keeps running
Handle retaining nut either came loose or broke off. Check the flapper valve, if its not completely closed water will keep running out, and fill valve will stay open trying to fill the tank.
Uberhaus canada
Usual issue is a worn or misaligned flapper. Could also be worn parts in the fill valve.
Jul 17, 2014 • Home
2answers
Where can I get a fill valve for Pegasus toilet
Use a fluid master universal fill valve, if it fits the tank. It will work as long as no part of the unit rests agains the side of the tank, if it does it will keep the float from rising.
The toilet tank takes a long time to fill up
if the water keeps flowing then try replacing the flapper if it still flows then the fill tube gasket or tank to bowl gasket need to be replaced.
Mar 23, 2013 • Home
Toilet does not stop filling, water keeps running
Replace your toilet fill valve with a fluidmaster 400A
Click here
http://411plumb.com/how-to-replace-your-toilet-fill-valve-with-a-fluidmaster-400a
heatman101
After each flush, the tank fills but the fill valve doesn't stop and the water keeps running into the toilet. How could I adjust the fill valve?
Usually the problem is dirt in the fill valve and not an adjustment problem...
depending on which valve you have it can be taken apart and cleaned out... just remember to turn off the water supply before taking the fill valve apart...
THE WATER KEEPS FILLING PAST THE OVERFLOW.
Replace fill valve. Fluidmaster works quite well and is very adjustable.
1helpful
Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Aug 04, 2009 • Home
Villeroy Boch subway toilet cistern filling up to much
On this model am not sure if it come apart. But if you have a air compressure try and blow though it. when you have it off toilet. sounds like its dirt caught in it.
hope this helped. :)
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
Top American Standard Home Experts
Mike
john h
Ekse
Are you an American Standard Home Expert? Answer questions, earn points and help others
