Can you really pop balloons with a laser pointer?
Posted by molly marks on
jon david
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 34 Answers
Yes you can, but these lasers a very dangerous because they run at much higher mWs (miliwatts) than the ones you would use when making a presentation in a lecture and are pretty expensive running at around $100+.
Posted on Sep 11, 2013
High Power Laser Pointer will damage my camera ?
The light from my laser pointer on a screen will not damage the camera a direct shine into the lens of the camera may well burn the electric of the eye out the camera may not be able to handle the intense light and it may bring out the circuits.
Nov 25, 2014 | Logitech 2.4 ghz cordless presenter
Tip
Safety first when using a laser pointer
Although a laser pointer may not look it, they can be very dangerous. While they can be a very effective tool for drawing your audience's attention to things in your presentations, using them for other purposes can cause a lot of damage. Following a few simple safety tips will ensure that no one will get hurt while you're presenting.
- Never point your laser pointer at an other person, especially not the face. Just because a laser pointer may not be dangerous when pointed at the skin of another person it is still a good practice to never use it to point at people.
- Never look directly into the laser beam, even if you are sure that the strength of the laser is not high. Even a low powered beam can cause some damage to the eyes. Eye damage can be permanent so it shouldn't be treated lightly.
- Check for reflective surfaces before you present with a laser pointer. If the beam is reflected off an other surface such as a mirror or glass can be just as dangerous as pointing it directly into some one's eyes.
- There is something about a laser pointer that makes people act like children. I have been in many college lectures where a lecturer will use a laser pointer to make emphasis in class and students will ask to play with the pointer. Under no circumstance should you allow someone else to use your laser pointer, especially in a classroom full of people.
If you feel uneasy about using a laser pointer in your presentation you might want to look into using your computer mouse as a laser pointer. Microsoft powerpoint has a feature that will allow you to use the mouse pointer as a laser pointer on the screen. That by far will be the safest laser pointer.
on Jan 29, 2014 | Office Equipment & Supplies
Can the infiniter 100 red laser pointer pop balloons?
STEP MOTOR TEST-
Enter TEST MODE-
1.) Plug in foot pedal
2.) Press reverse button and hold while turning on the power switch.
Advance through test segments by pressing up/down key
LCD shows "STEPPING MOTOR"
• Raise irhe needle bar to highest position and push
START/STOP key
• Lower the needle bar to lowest position and push
START/STOP key
• Tum the handwheel and check the feed dog position
SYPMTOM's
• Not working correctly
• Stepping motor (zigzag) get default position
• Feeding, tension motors get default position
• Feed dog goes to home position
SOLUTION's
• Replace stepping motor
• Replace tension sensor
Jul 02, 2014 | Office Equipment & Supplies
Keyspan remote control (mouse) Model TSAM - 004
Press and hold the two buttons (small pink and clear pie shaped) for 4 seconds. the lower button will flash red once every three seconds to show laser pointer enabled. Laser pointer turns itself off after 10 minutes on non-use.
Jan 13, 2009 | Keyspan Presentation Remote Control
706 people viewed this question
Marvin
Marvin
