SOURCE: Call of Duty Modern Warfare 2 for PS3. Getting
if you have a usb flash drive.
copy your game save files to it and delete the whole game including the saved games.
re-install and you should still have your saved game on the usb stick
copy this over and it should work.
if its the game save itself that is corrupted, then i'm afraid you have to start the game over again
Search 'how to copy ps3 game saves' and you'll find plenty of good step by step instuctions
SOURCE: PS3 CORRUPTED DATA
does he have problem saving any other games if so sorry to say he may have a bad hard drive or one that is about to die. you can try reformatting it. go to settings>system settings>restore ps3 systems once there u can start to reformat your hard drive. note it will erase everything he has on the system. and if u downloaded any games from the psn you can retrieve them under the download management. you just have to redownload them. before reformatting though try this method.
turn the system off from the back.
turn it back on. (it should be in standby mode now)
press the power button and keep your finger on it till it beeps three times. (its about a second apart.) and turns off.
take your finger off of the power button and press it again.
this time keep your finger on it till it beeps twice quickly and take your finger off.
it should tell you to connect a controller with a usb
once u do i'll give u a menu.
select option #3 and let it finish
this option will fix most minor software side problems
if this don't help u may want to reformatting your hard drive and hope u don't have to replace it. and before u do if u have any game saves u want to save u can copy those over to a usb flash card
SOURCE: My ps3 shut down while restoring default & now
You are going to have to format your hard drive unfortunately, there is no solution to your problem because by shutting off the system during setting the system back to its default settings you corrupted the data on the hard drive.
When I switch on my PS3 i get a error message stating hard disc is corrupted. I tried restoring but still the same error message. I used safe mode to restore but still it doesnt work. Before I format, I would like to copy my saved data to my USB. Please guide.
