Pure Digital Point and Shoot Video Camcorder Logo
A
Anonymous Posted on Sep 11, 2013
What kind of memory card does it take - Pure Digital Point and Shoot Video Camcorder
What kind of memory cards fit into a Akai Digital Camera DC7370
It uses SD cards. Make sure you get an SD card and not a higher-capacity SDHC card.
1helpful
3answers
Corrupt memory card
Put it a card reader and format it. That should resolve the problem.
May 06, 2011 • Cell Phones
What is SD card ?
A kind of memory card for some products as mobile, camera and so on, there are size kinds of SD card. Generally cameras using larger ones and mobile using smaller ones. batteryfaq_1.jpg
4GB High Speed SD Memory Card
4GB High Speed TF TransFlash micro SD Memory Card
Feb 21, 2011 • Cameras
14helpful
4answers
Memory card not formatted operation failed (in nokia 3500 classic)
Well, I met this kind of problem before. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted to learn the solutions or causes. Best regards.
My 6300 restarts automatically when i insert any memory card why?
hi
there are some phone that will restart when memory card is inserted automatically for first time. but make sure that your phone will support the memory card that u use. if still problem arises kindly try your memory card in other phone if it works properly means the fault is in your mobile. kindly format the phone and try it. this will fix your problem..
thank you
Memory card not working
hi
after inserting a memory card kindly restart your phone. make sure that your mobile willl support the memory cart tat you use. if so try it by restarting your mobile. if still same problem in memory card means try your memory card in other phones. if memory card works in other phone means there is some software problems in your phone. kindly ask your service men. if memory card is not working in other phone means then there must be fault in your memory card..kindly try it
thank you
My phone can't read memory cards
hi your phone is compatable with on certain kinds of memory cards and will not work with every other card available in the market. Kindly check your phones user manual and see what kind of card is compatiable with your phone. If even this doesnt work then i think your phones memory slot isnt working and u need to get it checked with an authorised dealer
Memory card error in 8GB card
Try to re-insert the card. If that doesn't help try to reformat it/delete all its contents. Also check in the manual what kinds of cards does the camera generally work with (although i doubt that is the problem).
1helpful
Memory card
To my knowledge, the Vivitar ViviCam 3315 has an expandable memory by using a Secure Digital (SD) memory card up to 2 Gb as shown here.
As to your other concern, that of the manual, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Top Pure Digital Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tony Parsons
Tony Parsons
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
