Subwoofer output issue 5.1 setup. 2 speakers connected to RF and LF speaker A terminals for music. Sub connected to sub terminal. 5 Speakers connected to Speaker B terminals for movies. No subwoofer output unless both A and B selected, resulting in all 7 speakers playing. Disconnected the A speakers, still no output from sub with only B speakers selected, but get 5.1 with A and B selected.
SOURCE: multiple speakers on zone 2 0r 3 speaker output terminals
I wouldn't hook anything up except what Yamaha recommends to the speaker output terminals. That's pretty much asking for trouble!
barneyluc
SOURCE: Surround speakers work in test mode but won't come on during play
Check that you set it to Pro logic and check the speaker set-up. Set it to 5.1 Sounds like somthing is in the wrong setting.
SOURCE: The subwoofer is not working on our Bose 5.1 surround speakers.
First of all you should never indicate speakers as Large unless they can produce below 20Hz (which is very low), otherwise always set your speakers to Small.
Second, did you also indicate in teh setupmenu that you have a subwoofer? Because if all speakers are set to Large some receivers will omit a subwoofer because Large indicates the speakers can reproduce all sounds even below 20Hz.
So walk through your setup menu, say YES when the sub (SFW) is asked for and that should do the trick.
SOURCE: Can I use front preouts for subwoofer?
First, you have to have a self-powered subwoofer (or two) with this reciver. That means the sub has its own amplifier. These are usually capable of accepting either Line Level (RCA) input or direct L and R amplifier channel speaker wires from your receiver from which it will react only to frequencies in its range. It doesn't actually use any if the power from your receiver's amp.
That is why you can extend your front speakers from the sub. Again, understand this - it is not playing any part in amplifying them. The amps in your receiver are just passing through it.
Setting your speaker 'Type' definition to Large will tell your receiver that they are capable of real bass (as opposed to small satellites) but won't necessarily steal anything from the subs. Set your LFE/Bass Out setting to Both if your front speakers are capable of handling real bass. Why would you want to deny them bass if they can handle it?
This part is confusing "If I can get the sub working on taking the lows out of the front speakers if I set them to large on the receiver then that is one thing less to send to the other sub on the LFE channel". The crossover feature allows you to define what bass goes to the sub. You would use the various points to smooth out the transition between your sub and the rest. Your quote of 47hz spec for something doesn't suggest your other speakers are great bass reproducers. One needs to see the +- db spec with less than x% distortion for that number make any sense.
Your receiver has two RCA Subwoofer Outputs but I'm sure they get the exact same level. If you're having trouble matching two different subs doesn't at least one of them have an adjustment for volume? Or maybe you could use physical positioning to adjust their comparative volume.
