The screw section is probably for the house speakers. ( if they are still on the other end of those screw's wiring.) If you have a working speaker on your computer you need a jumper wire or sorts. Buy, build, or make it by cutting one your speaker wires a couple feet behind the speaker and stripping an inch of insulation to get to the bare wire.
Get some music on the speaker you use for testing. Cut the wire and remove an inch insulation from from the cut end coming from the computer. (you test and learn how to do this - hook it back up to the speaker wire. See if you made work again.)NOW THEN! Take the jumper wire ( there are at least two.) and start touching it to any of those two screws. If your computer was and still playing music after you cut the speaker wire or inserted a test plug with speaker wire - you will be able to locate speakers connected to that site.
This p in to that live speaker output has a lead out with 2-3 bare wires on the end to connect to the on the on the other end have the two pieces of wire with a speaker disconnected. to touch to those
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
SOURCE: Connecting DVD player to AV receiver
If you've done that already and still no response from your system, I would suggest to take back to the place where you bought it and ask them to check it for you. Tell them that you follow the user's manual to the "T" but still unable to make it work.
Good Luck.
SOURCE: All my speakers don't work.
Did you press the "TEST" button on the remote? It will send some white noise to each speaker that is hooked up, one at a time.
SOURCE: Denon AVR-587 Television input stopped - no sound
try plugging another device into the tv input and mank sure you have the input mode is set to auto if you still have no sound those inputs are gone
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-587&imageField.x=106&imageField.y=8
