Question about Konica Minolta Bizhub Press C6000 Copier
Konica Minolta C6000: Fiery Controller error code 2H
The system throws an error saying "Controller Not Connected" and the controller itself shows an error code "2H" on the LED display. Is there an error code reference I can look up to find out what this means? Thanks, SB
3 Related Answers
firecontrol7
Norman J Weimar Jr
  • 6960 Answers
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jul 25, 2009
Anonymous
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Posted on Mar 08, 2010
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
How do i reset the error code c2704 in konica minolta press c6000/7000
Thread 2704
Abnormality in the black charging unit.
Possible causes:
Black charging unit
HV Unit
Print Control Board
Best guess is that you have a faulty charge unit. Try swapping the units around with another colour and see if the fault code shifts.
Nov 01, 2014 | Konica Minolta bizhub Office Equipment &...
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
Controller not connected
It might be the sequence you powered up. Turnoff the main power switch in the body amd the controller power. Restart the controller, this will take a few minutes, then restart the printer. Also check cables between the controler and the printer.
If you have Vcare (the service the communicates various conditions and usage data to KM), then unplug that cable, you might need your service tech to reset something. Your printer will work without the connection
Hope this helps
Mar 22, 2014 | Konica Minolta Bizhub Press C6000 Copier
Konica minolta bizhub 7000 controller doesn't turn on
Turning the Power On or Off - Konica Minolta Online Manuals
manuals.konicaminolta.eu/bizhub-C554-C454-C364.../id10-0061.html
bizhub C554 C454 C364 C284 C224 ... The Main Power Switch of the machine and thePower key on the Control Panel. No. Name, Description. 1. Main Power Switch. Press this switch when turning on or off the main power of this machine or ...
[PDF]C7000/C7000P/C6000/C70hc/ C6000L
myworks.sindoh.com/upload2/.../d37800822888835787371.pdf
KONICA MINOLTA Confidential. 2. C-2721, Intermediate .... v) Execute Printercontroller calibration for every output profile. (Standard ..... Start CWS5 and login to a Fiery controller. ii) Click [Calibrate] ...... If FD skew doesn't remain,. FD skew ......*A1DURX01: For bizhub PRESS C7000/C6000 and bizhub PRO C6501. 2.
Feb 15, 2014 | Konica Minolta Konica Kit For Bizhub Press...
IC 601 controller is connected to my konica minolta bizhub C6000 printer but display is showing controller is not connected
check the cable between the print controller/firey and the copier, also is the print controller/firey set up for a c6000
Feb 07, 2014 | Konica Minolta Office Equipment & Supplies
The printer says controller not connected
Check the cable connections between the printer and controller.
Restart the printer. If that does not work then turn the printer off and restart the controller then turn the printer on.
Oct 18, 2013 | Konica Minolta Bizhub Press C6000 Copier
Konica Minolta Bizhub Press C6000 Copier Logo
704 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
