Is there a replacement remote or universal remote for my Toshiba stor.e tv+ media player.
To choose the right remote control, you have to know about the setup codes to your brand device. To get more details about the setup codes, check the sites linked here. It has setup code list and setup procedure to many popular brand remote controls. Check it, find out which brand remote control have setup codes to your device, and buy that brand universal remote control, according to availability.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or
type in the brand name and model number to of your set, to its search
box, and press 'Enter' or view it in Mosaic / Timeslide option.
SOURCE: Universal Remote code for VCR/DVD recorder.
Use the remote's "Code search" feature. It'll run through every code in it's database and when you see the player turn off, you store the code. If non of the codes work, then it's not compatible.
Hope that fixed ya...
Geno
SOURCE: toshiba tv code for Zenith remote
Check the manual for your Zenith; many of the Zeniths (and many others) have a 'scan' mode you can call up, in which you can repeatedly press one key (^ for example), then the Power Button. That will force the remote to set every code it has available, step by step.
If you no longer have the manual, you may find it here or several other sites that offer these.
SOURCE: programming my toshiba universal remote
http://www.tacp.toshiba.com/tacpassets-images/models/27AF45/docs/27AF45_om_E.pdf
Scroll down to the remote section page 12 -13 its in there... I have this same remote and just programmed it.. Good Luck to you!
SOURCE: tv codes for a rca universal remote controller
need remote control codes for a toshiba 32A35 with a rca remote
