Question about Measuring Tools & Sensors
How do I set the correct time zone on my Sharp weather station / atomic clock?
Posted by Susan Dunlap on
John S.
    New Friend:
  • 3 Answers
On the SPC595, there were no specific instructions to set time zone, either (default was Pacific, I'm in Eastern), so I'm hoping that what worked on this will work on your unit:
Try hitting the "UP arrow" when the clock is NOT in a setting mode. This is not referenced in any "setting time" area but rather the area of the instructions that tells you what each button does. My manual (if you can call it that) says the following:
"UP Button
In setting mode, press it to increase the setting value. Press it to switch the time zone P/M/C/E"
Posted on Oct 12, 2014
How do I set the time?
An atomic clock should set itself automatically using a time server. That is the whole idea.
This may be the manual on it?
Sharp SPC900 Instruction Manual
Feb 10, 2016 | Sharp Atomic Weather Station Alarm Clock
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
Instructions
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more : http://www.ehow.com/how_5698886_set-sharp-atomic-wall-clock.html
May 08, 2015 | Audio Players & Recorders
Changed batt now how to set time
https://www.sharpusa.com/CustomerSupport/ProductDownloads
Find and download you manual for the instructions
Jun 29, 2014 | Sharp Weather Station Atomic Clock
How do i set time zone on sharp weather station pcs775
"UP Button
Oct 27, 2012 | Sharp Atomic Weather Station Alarm Clock
I lost the instructions for the talking Reizen atomic clock and both of them are now an hour off. How do I reset the time?
You need to change the 'Zone' settings on both; the signal from Boulder, CO can't tell where you are, you have to make the correction locally and then they will track the signal accurately as long as they can receive it.
Nov 27, 2011 | Reizen Atomic Talking Clock
Can not set time zone
Press the triangle shaped button to set the correct time
zone. It will toggle the clock mode through the four available time zones in the Continental U.S. Above the seconds digits, the LCD display will indicate "P" for Pacific, "M" for Mountain, "C" for Central and "E" for Eastern.
Mar 01, 2011 | La Crosse Technology WT8005UB Atomic...
How do I set the time? It's 8:51 right now and the clock says 6:51
the manual is at this address http://www.lacrossetechnology.com/8005b/manual.pdf , look on page 5 to set the correct time zone for your area. good luck!!
Nov 16, 2010 | La Crosse LaCrosse Atomic Digital Wall...
Sharp Atomic Clock spc 373 won't display correct time/zone
To change the time zone press the "time" button, on the front the space that shows the date will change to show the time zone. With the time zone showing press the "up" or "down" button to get to the correct time zone.
Sep 23, 2008 | Zapf Chou Chou 716212
Measuring Tools & Sensors Logo
947 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
