Computers & Internet Logo
cal dornbush Posted on Sep 10, 2013
Laptop plugged in but not charging
After shutting down my laptop and turning it back on I proceeded to plug it in. Upon plugging it in it doesn't charge. I have switched ac adapters plugs and still it won't charge. It will then randomly restart charging and continue on as if nothing had happened.
Kevin Gossett
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Sep 11, 2013
Kevin Gossett
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
771
Points
16
Does the battery get hot when it is on the charger. Possibly a bad battery.
5 Related Answers
Anonymous
  • Posted on Aug 25, 2009
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
mrstan
Stan Skaggs
  • 242 Answers
  • Posted on Aug 29, 2009
SOURCE: Dell Vostro 1000 shut down and won't turn back on
nope, it is your dc power regulator board. you will note this happens if the battery is in or out of the laptop. that is the key test. some regulators are on the main board and some are seperate for this reason. I think the vostro though is on the main board. A little board re-work will resolve this issue after replacing some components, but this is way beyond a home user's ability.. trust me on this. Sorry for the bad news. Thanks!
mrstan
Testimonial: "Thanks for your answer. I guess I will check what the repair costs may be, and if too much, just get a new machine."
Anonymous
  • 1481 Answers
  • Posted on Dec 29, 2009
SOURCE: My Dell 5160 laptop slows down with the AC adapter plugged in.
try running ur laptop using the adaptor without the battery in it's place and run it with just the battery...note the difference....it may be a power surge/short issue....some times the battery is supplying power along with the adaptor to the notebook and the power circuit in there is not able to take dual power....check your power options setting in Control Panel...
also do this
clean ur system use Tuneup Utility get it from my website Dowload page
www.sureshayyar.110mb.com
use all the tools and option in that tool...the best is 1n Click Maint in there .....it fixes all ur issues...
Anonymous
  • Posted on Jan 09, 2010
SOURCE: Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Anonymous
  • 942 Answers
  • Posted on Jul 04, 2010
SOURCE: Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Will no turn on & yes it is charged
unplug it and take the large battery out of it. also make sure that no cd or dvd disk is in it and also UNPLUG THE PRINTER AND ANYTHING ELSE TO IT.. NOW PLUG IN THE POWER SUPPLY ONLY AND TURN IT ON. IF IT COMES ON AND WINDOWS COMES UP THEN SHUT IT COMPLETELY DOWN AGAIN, UNPLUG IT AND PUT THE BATTERY BACK IN. NOW TURN IT BACK ON. IF IT WORKS SHUT IT DOWN AGAIN AND PLUG THE POWER SUPPLY BACK IN. NOW TRY IT AGAIN. IF IT WORKS NOW, ONE AT A TIME, PLUG PRINTER IN AND TURN ON. DO THE SAME WITH ANYTHING ELSE THAT NEEDS TO BE PLUGGED IN. GOOD LUCK.
LAPTOP WON'T COME ON
2answers
1helpful
Battery not charging on aspire 5736z
  1. Install the BIOS. (from acer website)
  2. Reboot, log back on, delete the "Microsoft ACPI-Compliant Control Method Battery"
  3. Shut down.
  4. Removed the battery, unplug the power, waited a few minutes, tapped on the keyboard with voodoo chicken feet.
  5. Plugged it back in without the battery, booted it
  6. Logged on, deleted the ACPI driver again.
  7. Plugged the battery back in (hot, not shut down)
  8. Rescanned for hardware changes.
Laptopp plugged in not charging
What's your OS? Someone claimed to have resolved this problem following the steps below:Shut down Computer. unplug AC. Take out battery. Plug in AC. Start up computer. Disable Microsoft ACPI CC Method Battery Shut down computer. Unplug AC. Insert battery. Plug in AC. Turn on. Enable Microsoft ACPI.
Then it was working.
Original post:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/gateway-laptop-plugged-in-not-charging/6db4fe50-d318-44da-a938-2fc58f4bbe7b
Of course, there were some different voice on this post. Have a read, and may this help.
I cannot move the mouse on screen- what do I do?
Make sure there is nothing plugged into any USB ports, restart the computer (or manually shut it down by pressing the button) and turn it back on. If that doesn't fix it, try plugging in a USB wireless (or wired) mouse and see if that works.
HP compaq 6735s Shuts facing a very weird problem concerning its power. I have left my laptop charging without use for 3-4 days, today I came back home and wanted to use my laptop, I turned it on and...
You need to replace the battery as it has expired.
They are available by typing the battery model number or laptop model number into ebay or Google or indeed any search engine.
Hope that helps.
Looks like your battery is having a problem. Remove the battery and replace after a couple of hours. If problem remains replace the battery with another to test, if this works, then the problem is with the adapter unit. Get a new one.
Hi , laptop works fine when fully charged and plugged in, but should i unplug it and run the battery down even as little as to 95% battery life ,when i plug it back in the laptop will not recognize that it...
just take the battery out of your laptop and plug it in again. this may help to overcome the problem still.. if you face the problem.. just trying replacing the battery by asking it with some of your friends. and if it works.. buy one for you.
Dell inspirion 1501 laptop, not charging battery light showing red, have bought a new mains adaptor but still not charging
Does the back dc jack seem loose when you have the ac adapter plugged into it? Wiggle the cord right where it plugs into the laptop. If it moves around then most likely the dc jack on the inside has one of it's 3 points of contact broken. This means that someone would need to re-solder that contact or put a whole new jack into the laptop. Another thing to try is replacing the battery. Sometimes they won't charge because they are bad. Another thing to try is take the battery out, plug it into the adapter, turn it on, get into windows, shut down, put battery back in, turn on. See if that resets the battery and makes it charge.
Battery charging problem on my asus x50rl, onto 2nd battery now, initial charge ok but will not charge up now
you may need to recalibrate the battery, to do this you need to run the laptop until it shuts down due to power, turn it back on and on boot press f2 or w/e your bios key is and plug it back in then let the laptop run until it dies again. plug it in and let it charge completely. i hope this helps
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
