Windows 7 startup error
Repairing took hours so i stopped it
Posted by jayvee_kraut on
Atiq
    Sergeant:
    Champion:
  • 257 Answers
It may be virus or hard disk drive problem, try restoring os from oem dvd...
Posted on Sep 10, 2013
UNABLE TO START MY LAPTOP
Original Title:your computer was unable to start......startup repair is checking your system for problems
i have a new toshiba satellite p505-s8970 with windows 7 preinstalled when i first took it out the box and turned it on it started up fine after i connected to my network it stop responding and shut down tried to start it back up it goes to the startup repair utility and stays on that screen i've let it run for hours and nothing happens is there a way around this....is there a way i can start in safe mode to try and figure out whats goin on
1helpful
Dell-n5050 laptop; windows failed to start; code-0xc000000e; boot failed because required device is inaccessible. I have Dell OS media stick. and is there a free fix for this problem?
That code is a Windows boot error. I'm not sure what you can do with the Dell OS media stick but the traditional solution with a regular hard disk is to take a Windows 7 OS disk, boot with it, and run startup repair. Here's a link to Startup Repair: Startup Repair Microsoft Windows
2answers
My pc with windows 7 ultimate got stuck on the startup. usually, when you start the pc, "starting windows and windows icon" appear and after that, welcome and your desktop. but in my case, ONLY the...
Back up all data and re-image the computer. You can either use a windows 7 disk or create a bootable usb. there is likly a problem with the boot manager.
My toshiba n723 says i need a windows 7 start up disc. where do i get this?
you just need to repair windows startup. and you can do it by bootup window 7 disk and go to repair opption and find startup repair opption.
this opption will solve out this problem automaticly.
Stuck in startup repair on a windows 7 notebook
Use the repair option to reinstall Windows 7. This should load on top without wiping system.
Download this tool and make a USB Windows 7 Installation drive.
http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool
Bootmgr missing error on startup
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
a) Insert the Windows 7 System Repair DVD or Installation DVD and reboot.
b) Select the correct keyboard input method and click 'Next'.
Note: If you are using the Windows7 Install DVD then at the 'Install Now' prompt (Do not pick the Install
Now option) instead choose the 'Repair your computer' option located in the lower left of the dispay.
c) The System Repair tool will search for a valid operating system and will report that "Windows found problems with your computer's startup options. Do you want to apply repairs and restart your computer?"
d) Click 'Repair and restart' and reboot again to the Windows 7 System Repair environment.
e) Click 'Next' at the keyboard selection prompt and when the 'System Recovery Options' screen appears verify that the "Use recovery tools that can help fix problems starting Windows" is selected.
Note that on your Dual Boot system there now should be only one operating system listed. Click the 'Next' button.
f) Now from the menu list select the 'Command Prompt' option.
g) At the DOS prompt type the following three commands:
bootrec.exe /fixmbr
bootrec.exe /fixboot (may return an 'Eliment not found' message)
bootrec.exe /RebuildBcd
h) Close the command prompt window and click the 'Startup Repair' option.
i) The repair process may take some time, so wait until the process completes at which point you will see two messages "Windows cannot repair this computer automatically" and "Startup Repair cannot repair this computer automatically".
These messages are the result of the radical changes made by removing the other drive. Ignore the Send/Don't send options.
J) Close this message window by clicking on the X in the upper right corner of the Send/Don't send window. Next click on the 'View advanced options for system recovery and support' option and from the main menu once again click 'Startup Repair'.
This time the repair process may only that a few seconds and when prompted "Startup Repair could not detect a problem", click 'Finish' and run the 'Startup Repair' option one more time, click 'Finish', and then remove the System Repair DVD and click 'Restart'. Reboot the computer.
hope this helps
Computer turns on and after its done showing loading bar a blue screen appears . the computer then restarts with a black screen showing start windows normal, or startup repair. i chose startup repair
Try running the Check Disk Utiltiy.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
2answers
Windows 7 wont start
LOL, I wouldn't give up my windows xp for anything else.
OK, what does it do that requires you to keep trying to get it to boot? Are you getting any error messages? Is it just stopping or freezing someplace in the boot cycle? Is it doing that stupid Startup Repair? What is it doing that causes several tries to get it to boot?
Stop:0x000000A5 (0x0001000A, 0x00000000, 0x00000000, 0x00000000)
"Stop: 0x000000A5" error message typically indicates that the computer BIOS is incompatible with the Advanced Configuration and Power Interface (ACPI) standard that is supported in Windows 7. However, this error can also occur because the computer hardware, the peripherals, or the drivers for those devices are incompatible with Windows 7.
Startup Repair from the Windows Recovery Environment (WinRE)
1. Insert the Windows 7 installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Refer the following link for more information:
http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7
Computers & Internet Logo
Ekse
