Intel pentium dual cpu e2200 audio drivers
Sound driver unintall
Posted by muhammad javed on
Atiq
    Sergeant:
    Champion:
  • 257 Answers
I need mother model number...
Posted on Sep 10, 2013
5 Related Answers
kershk
Kevin Kershner
  • 106 Answers
SOURCE: Intel® Pentium® Dual CPU E2180 LAN Card
download these drivers from intel.com
Posted on Jun 09, 2009
Anonymous
SOURCE: Compaq Speakers Sounds Like Alvin and the Chipmunks
I had the same problem and found this post on another site. It worked like a charm.
Dude Check It. i just fixed mine.. go to the main menu and go to sound effects you will then find a area that says karaoke put that on #0 and that should fix your problem..
This post has been edited by VoLt: Oct 8 2008, 11:51 AM
Posted on Nov 06, 2008
Anonymous
SOURCE: Compaq Presario SG1118IL Desktop PC all drivers
VGA DRIVER I WANT
Posted on Mar 17, 2009
rulds2008
Grand Canyon Tech
  • 3866 Answers
SOURCE: No Drivers
Ok it looks like you have some way to get on the internet witch is perfect. Go to www.driverguide.com they have all sorts of sound drivers for your pc.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 22, 2009
joecoolvette
joecoolvette
  • 5660 Answers
SOURCE: cpu upgrade , please help
tech-gu818,
When looking to see what processors a computer will support, try to find out what motherboard chipset is on the motherboard, and the processor socket.
The motherboard chipset is the;
1) Northbridge chip
2) Southbridge chip
[Chip and Chipset are slang terms for Integrated Circuit, or IC.
A Processor is one type of Integrated Circuit]
The Northbridge chip is responsible for handling the Processor, Ram Memory, and high-speed graphics, such as AGP, or PCI-Express.
Integrated graphics, or a graphics card installed in a PCI slot, is handled by the Southbridge chip. The slower capabilities of a computer are handled by the Southbridge chip.
This motherboard diagram may help further illustrate the above statements,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
(You can also type,
1) Northbridge (computing)
2) Southbridge (computing)
in Wikipedia's search box to obtain more info )
How to find out what motherboard chipset the eMachines W3502 uses?
Three ways:
1) Go to the computer manufacturer's support website, and look under Specifications.
2) Download the free, tiny, program CPU-Z from CPUID.com
3) Download the free, tiny, program Belarc Advisor
Fortunately eMachines Support lists what the W3502 motherboard chipset is,
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W3502
Chipset: ATI Radeon XPress 200
Now look for information on ATI's Radeon XPress 200 chipset.
For this we can go back to Wikipedia once more,
http://en.wikipedia.org/wiki/Ati_radeon_xpress_200
Reading the top sentence in the first paragraph you will note,
".......Pentium 4, Pentium D, and Celeron processors, ......using either a Socket 478 processor socket, or an LGA 775 processor socket."
What isn't stated in the first sentence is that it will also support Intel Core2 processors. That is stated on the right side of the page, in the information box under the subheading - CPU Supported
I wouldn't think anything higher than an older E4400, or E4500 though.
The E4400, and the E4500 use an 800MHz Front Side Bus. So does the E5300 Dual Core.
The information box states that processors with Up To a 1066MHz FSB are supported.
I just don't know if there is a BIOS update needed, or if a BIOS update is available, in case it's needed.
Needed to change the voltage, and multiplier, so that a processor with a 1066MHz FSB can be used.
To summarize:
The ATI XPress 200 motherboard chipset, on your eMachines W3502, will support an Intel Dual Core E5300.
Advise:
Do Not forget to use anti-static precautions. Your body carries Static electricity. Static will fry out (Short circuit) computer hardware components.
A Processor is the most susceptible hardware component to static shock.
I would advise buying a cheap $6 ESD wrist strap, from some where like Radio Shack, or a similar store, and using it.
Clip the alligator clip to an unpainted surface of the metal frame, of the computer case. (Computer unplugged from power)
Barring this, make sure you touch the metal frame of the open computer case, before you reach inside. (Computer unplugged from power)
If you get up, and walk away in the middle of working on your computer, upon your return touch the metal frame again.
Make Sure the top of the Processor's case is clean, and the bottom of the Heatsink.
I use an old credit card to scrape both surfaces as clean as I can, then follow with Q-tips dipped in Isopropyl Alcohol.
Usually takes a few dipped Q-tips, as thermal paste is a gooey mess, and the alcohol takes time to break it down.
Isopropyl alcohol is also referred to as Rubbing Alcohol. 91 percent is best, but 70 percent will do. Nix on the 50 percent.
CAUTION!
Isopropyl alcohol is Extremely Flammable! Use in a well ventilated area, with no sparks or flames present.
Use fresh, new thermal paste, never try to reuse old thermal paste, or a thermal pad. Thermal paste properties break down over time, and the thermal paste becomes more of an Insulator, than a Conductor.
Thermal pads are only good for taking off, and flying at the cat.
They're Junk!
(Meooow! Hey watch it dude! You almost hit me with that!)
Thermal paste doesn't have to be Artic Silver 5. A good quality thermal paste, applied correctly, will get you down the road just fine. A 'Mom and Pop' computer repair shop, should have a one processor tube, for around $2.
You Should be okay with the same Heatsink/Fan combo, as the Intel Pentium Dual Core E5300 puts out less heat than a Celeron D 352, or around the same amount.
Be sure the inside of the computer sparkles, as well as the Heatsink, processor fan, and the inside of the Power Supply. Use a can or two, of compressed air for computers.
(Celeron D's are not dual core processors. The Pentium D's are)
Posted on Mar 25, 2010
Testimonial: "thanks... really hepls..."
the sound is not integrated in the processor, the motherboard need a sound driver
Pentium r dual core cpu e5300 audio drivers
Audio drivers are for the motherboard/computer, not for the cpu. Go to computer maker's website (or motherboard maker), locate the support page for your exact model and download the drivers there. Also, Windows update may be able to supply generic drivers that will work. Go to Start / Control Panel / Device manager and locate your Sound drivers and click on Update Driver.
Intel Pentium Dual CPU E2200 @ 2.2GHz
the driver depends on your hardware (chipset on m/b and any cards that you have) and the operating system, not the CPU. Please supply your o/s and hardware information
2helpful
Sound driver download e2200
you installed correct drivers?
if yes,remove and again enter the plug of speakers at the back of cpu
cant play the song ! Cpu e2200 window 7 64bit
the drivers of it are not there i hav tried much but dnt know how to.
1helpful
I want sound driver
i want to download freeware audio driver software for intel r pentium r cpu e2180
9helpful
Intel Cpu Pentium Dual-Core E2180 2.0Ghz Fsb800Mhz 1M Lga775 Tray Logo Problem with the Intel Cpu Pentium Dual-Core E2180 2.0Ghz Fsb800Mhz 1M Lga775 Tray I have no audio driver for my pc
every other detail...but...motherboard...assuming it has onboard sound.. google drivers for the make and model of your motherboard soundcard should be there somewhere.
5helpful
I want drivers for this type of motherboard Intel(R) Pentium(R) Dual CPU E2200 @ 2.20GHz
You shouldn't need drivers for this board, it should work regardless. If you feel like you do need them however, a download link is here.
2helpful
How i can install my LAN to my pc, intel pentium dual core e2200 2.206GHz
The LAn drivers installed automatically when you run recovery CD, otherwise you can download drivers from here and install
good luck
51helpful
Computers & Internet Logo
Ekse
