Question about LG LFD25860
Replace pc board 6871jb1064
L need a replacement pc board for the above refridgerator
Posted by rm kwembeya on
How do you rlace the circuit board on a fridgidaire side by side refridgerator
Thank you for your post, friend!
From my understanding you need to replace the circuit board on your Frigidaire side by side refrigerator. In order to replace the panel you would need to disassemble the front dispenser to access the needed wire for replacement of the panel. This is not a simple DIY job and I would recommend seeking assistance from a professional technician. They will have the appropriate tools needed for proper disassembly of your refrigerator. Best of luck! -Matt
Mar 09, 2015 | Frigidaire Refrigerators
THE REFRIDGERATOR DOESN'T WORK ABOVE SETTING #3 AND GOES TO 10 DEGREES AT SETTING 3 OR BELOW
heck for good clean and tight fitting connection of thermistor to control board. If this is OK, then a diagnosis of the thermistor resistance to temperature is needed. If it is OK you could have a bad (stuck) relay on the control board.
Nov 22, 2012 | Dometic RM2652 Refrigerator
CE alarm panel display Electrolux side by side refridgerator
Hello Roy Avila - Typically error code CE indications a communication error at power up. You would need to contact a professional to check the wiring between the main control board and user interface board. Technician will need to move forward accurately and either part will possibly need replacing.
Oct 04, 2012 | Electrolux Refrigerators
Lights on inside but keypad and refridgeration not working
According to your description, you will need to locate and replace the main control board on your unit, if you roll out the unit from the wall, as you are looking at the back (from the back) your will see a metal panel bottom middle on the right side. Inside this panel is your main control board, The factory part number is WR55X10942. Also please verify model number as you are missing a run letter should be A-D after the P in the number you supplied above. Although is board is the same in all models.
This should fix the issue you have and get you back running again.
God Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Oct 11, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Flashing control panel, ice/water not working, ice release flap constantly opening and shuting
Had the same problem and you need to replace the main circuit board on the back lower left of the refridgerator! Cost about $125.00 for the board and comes with instrutions!
Apr 22, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
My ice maker on the freezer side door stopped working so I changed out the motherboard CCA in the back of the refridgerator & it started working again but the water did not. I need to replace the...
Blake are you talking about the dispenser control board? The ice maker tells the water control valve to come on for the preset amout of time to refill the ice trays most times about 7.5 seconds. and filling ice maker with tap water will test icemaker. If water freezes and the ice dumps the signal is sent to the water control valve Click here=> WR57X10050 here is a service manual=> PROFILE ARTICA SERVICE MANUAL CLICK HERE Have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Light and temperator display out on refridgerator side
Had the same problem. Someone on this board told me about this circuit board. I found one online for $73 and replaced it myself.
Part Number: AP4334000
Made by WHIRLPOOL
Check out this website:http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136804&diagram_id=935861#d935861
Jan 03, 2010 | Whirlpool GS5SHAXN Side by Side...
The compressor is not running and there is a clicking noise coming from the circuit board panel on the back of the refridgerator
You have to replace the main control board . The clicking is the compressor board relay , which the only repair , is to replace the main board .
Sep 11, 2009 | GE Refrigerators
LG LFD25860 Logo
279 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
