That error code refers to the pressure switch which is jammed on full. Remove the lower rear cover from the machine. Remove the large black pipe attached to bottom of drum. Clean the plastic filter inside this pipe. Remove the pipe that is attached to the pump and check for blockages or obstructions there as well.
Error code F05 denotes pressure switch jammed on full.
Remove the lower rear panel of washer.
Remove the large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Error code means pressure switch jammed on full.
Remove lower rear panel of washer
Remove large black hose fastened to bottom of drum
Remove hose on to pump and check for blockage or obstruction here as well
Thankyou.
The top cover can be removed by undoing screws at rear of cover, and sharply pushing forward on cover to remove.
The lower rear panel of washer is also removeable.
Error F05 means the pressure switch is jammed on full.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum.
Clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here as well.
Thankyou.
F05 means pressure switch jammed on full. Do the following. Remove lower rear panel of washer. Locate and remove the large black hose fastened to bottom of drum. Remove and clean filter inside hose. Remove hose onto pump, and check for blockage or obstruction here as well.Reassemble, and test. Please rate my solution. Thankyou.
Hi.
Yes there is a filter.
Remove large black hose onto bottom of drum.
Remove hose on to pump, check for obstruction or blockage here, and look inside the pump as well.
This should solve your problem.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
According
to the manual ‘TEST’ should only appear in the display when the hardware key is
inserted into the rear socket of the machine ready to commence a test sequence.
The only advice I can give is to turn the appliance off and remove the plug
from the power socket for at least one minute then plug it back in and try it
again. These machines have 3 phase motors and the heat sink on the module
retains an electric charge for some time after the appliance has been switched
off so be mindful if you decide to venture into the inside of the cabinet.
no lights at all?
take top off. check power present at suppressor capacitor (1st in line to power inlet) and power present at output from suppressor. you will needs a meter.
check on/off switch has power at input and output
