SOURCE: Overiding Empty Cartridge error for Dell A10 962
Hit the options button (just under the digital display on the printer) (and between the two arrows) 10 times. The hit the +arrow once to change. Go through the change motions again and you should get a new ink read.
Jim
SOURCE: ink cartridge
we just installed a new ink cartridges..it keep saying install new cartrigde..and so it doesnt print anything at all.
SOURCE: Reset the ink memory level after replacing cartridge
Have you tried to unplug your printer and plug it back in?
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
SOURCE: left ink cartridge incorrect. It is the right ink
A trick which may work is cleaning the contacts on both the cartridge and the printer.
Make sure you've switched it off first, I'd try gently buffing with a soft dry cloth first.
HP reccommend using distilled water and cotton buds, but not alcohol based cleaning fluids.
Allow the water to evaporate before replacing cartridge and switching on.
