SOURCE: Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
SOURCE: whirlpool gold quiet partner iv will not turn on
Hi chrslndsy,
I'm Harvey the Master Plumber.
Your problem is: whirlpool gold quiet partner iv will not turn on there is no sign of life in it at all.
Usually this indicates that the power is disrupted. First check the breakers. 9 times out of 10 it's a broken, loose or burnt connection in the d/w junction box. It's located underneth the d/w behind the kick plate on the right or center, depending on model. Turn the power off at breaker and remove cover. Take each wire nut off and repair/replce as nessessary. Test before you close it up.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: whirlpool dishwasher # quiet partner II
Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
SOURCE: RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Hello &
Welcome to FixYa
Press and
hold the AIR DRY/RINSE ONLY button to reset the control, if you have already
tried this and it is possible that the door was opened while in cycle then the
first thing that should be checked is the door switch/lock assembly. You can
take a hair dryer and try to blow air on that, if the problem returns then
replacing the door switch/lock assembly is recommended repair. Please get back
to me if you have any other questions.
Kevin
