If this is an LCD TV, show a flash light on the screen from a safe distance. If you can see picture, it means the backlights have gone off and the TV might need servicing.
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
The shadow mask in the picture tube has shifted from being dropped. The only way to fix the set is to replace the picture tube, which would cost more than buying a new set.
Do not try to align the colors with the remote. One of your convergence IC's has gone bad and needs to be replaced, possible burning one of the 3 low value resistors next to it. If you change the convergence settings now then they will have to be reset when the new IC is installed.
