Question about Dell DJ MP3 Player
Digital jukebox firmware hd001 - Dell DJ MP3 Player
My nomad jukebox zen xtra goes into Rescue mode (v1.13) where do i get thr firmware??
http://www.microsoft.com/windows/windowsmedia/player/11/readme.aspx#IssuesupdatingfirmwareonCreativeportabledevices
See this link.
Try unistalling Windows Media Player 11 from PC. and then upgrade ur device.
Follow necessary steps.
Mar 17, 2010 | Creative Labs Nomad Jukebox Zen Xtra MP3...
When it the zen is turned on it says firmware
Had the same problem and nearly went nuts trying to fix it. Here's what I did:
1. Uninstall all creative driver & creative software.
2. Uninstalled Windows Media Player 11 (Rolled back to WMP 10) and restarted PC.
3. Uninstalled Windows Media Player 11 Runtime and restarted PC.
4. Downloaded and Installed the latest free version of Winamp from http://www.winamp.com
5. Connected my A/C Power Cord to my Nomad Jukebox then connected my Nomad Jukebox via USB cable to the Computer.
The computer should then recognize the Nomad Jukebox as "Found New Hardware" then "MTP Device" and lastly "Your new hardware is installed and ready to use.
6. If you haven't already, go to the creative website and download the Creative Zen Xtra PlaysForSure Firmware 2.10.03 and save it to your computer.
7. Run the Firmware (Make sure Nomad Jukebox is connected) and at this point the Computer should recognize the Nomad Jukebox and begin the upgrade.
After your upgrade is complete, You can go ahead and re-download Windows Media Player 11 and it will recognize the Nomad Jukebox.Not sure what version of windows you have, but I have two computers, one with windows xp and the other has windows 7 and Im able to transfer music perfectly fine with Windows Media Player and RealPlayer on both computers. I hope this works for you. Good Luck!
Jan 05, 2010 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Where do you get firmware?
Follow the link below and you will find all the software.
Drivers and Firmware
http://support.creative.com/Products/ProductDetails.aspx?catID=213&subCatID=216&prodID=241&prodName=Creative NOMAD JukeBox&subCatName=Digital MP3 Player&CatName=MP3+Players
Jun 22, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Mad at my nomad
It appears that my Creative Nomad Jukebox is stuck in the Rescue mode. It displays the four options suchn as. 1.Clean up 2. Format all 3. REload OS 4. Reboot
It is not recognised on the computer either.
Steve
Dec 12, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Firmware problem
I have Creative Nomad Jukebox Zen Xtra 60GB.
I changed harddisc. "firmware problem"
Please help me.
Sep 04, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Zen Xtra 40 GB
Ok this is what I have found.....Try to run the Recovery Mode here is a link to Creative Labs website that will walk you through it... Just look for Jukebox its on the bottom...you can get the firmware from the same website under support and then just select the type of jukebox you have....that will be the second link...You will need to click on Zen and then look on the right side for Archived Products
http://support.creative.com/kb/ShowArticle.aspx?url=http://203.211.142.197:80/srvs/cgi-bin/webcgi.exe/,/?st=357,e=0000000000342903798,k=6058,sxi=1,varset=ws:http://us.creative.com,case=4794
http://support.creative.com/Products/product_list.aspx?catID=213&CatName=MP3+Players#
Good Luck and let me know if this helped
cbinny1
Aug 17, 2008 | Creative Labs Zen V MP3 Player
Proposed solution
Creative Jukebox 3
  1. Remove the battery cover
  2. Partially remove the battery
  3. Press and hold STOP button
  4. Slide the battery back into position - the unit should power on.
  5. When the CREATIVE logo appears on the display, release the STOP button then immediately press and release the PLAY button.
  6. The following options will appear on the display:
  • Clean Up (Performs a disk scan on the players hard disk)
  • Format All (Formats the players hard disk - Note: all contents will be lost)
  • Reload Firmware (Reloads the Operating System on the Jukebox. Note: Reloading your OS, will not effect the contents of the files stored on your Jukebox Zen. Select this option ONLY if you have access to a PC and you have downloaded the necessary firmware to install.)
  • Reboot (Reboots the device).
Aug 16, 2008 | Creative Labs Nomad Jukebox III MP3 Player
My creative nomad jukebox zen extra 30gb
means the software used to operate the unit is corrupt and you need to download and install a new version
http://us.creative.com/support/downloads/
Jan 01, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Dell DJ MP3 Player Logo
Top Dell Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Marvin
Marvin
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
