TX = Transmit. RX = Receive. Does your needle move when you key the mic? Does it modulate when you talk in the mic? Do you have an inline watt/SWR meter inline? What kind of a set up do you have? Mobile? Base? Get back to me if you want further help.
If you have confirmed your dead key being "great" the the two things that can be causing your problem is a faulty mic, mic wiring, mic connector (either on the CB i=or the mic connector itself.
Have you tried a different mic?
The other thing would be a bad antenna, antenna connection, SWR.
Have you tried a different antenna? Checked your SWR (with an inline meter)? Make sure the antenna connector (PL259) and the connector for the antenna on your CB (SO239) are in good condition and that there are no cold soldier joints.
If you have any comments please feel free to leave them here.
well you can put a bigger fuse in but your risking really messing something up. if it's blowing the same fuse over and over, then you need to move the positive wire. look up the wiring diagram for the car and find the positive wire going to your fuse panal, connect it to that with a 20amp inline fuse and you should be set.
In my experience...if it blows the fuse as soon as you turn the key, under the flywheel, there is a stator that recharges the battery when the engine is running, remove the flywheel, in most cases the magnets under it are broken and are in direct contact with the stator. If that is the case, both must be replaced
