LG Optimus Net L45c - Black net10 Smartphone Logo
Antonio Pizarro Jr Posted on Sep 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Touch screen It is not responding to my touch. It will not let me even answer the incoming calls. It keeps acting like Im touching it when I am not and entering its own incorrect unlock pattern.
Kevin Shafer
Level 3:
President:
  • Master 1,314 Answers
  • Posted on Sep 09, 2013
Kevin Shafer
Master
Level 3:
President:
Answers
1314
Questions
Helped
522903
Points
4446
Most likely the digitizer is no longer working. This is what detects the touch on the screen. The digitizer will have to be replaced or the entire screen.
Incoming calls on Sony Ericsson K800i used to prompt Answer/Busy options, but recently I get Send/Busy, both resulting in sending a busy-signal.
Try disconecting the base unit from power and phone line for 10 minutes and also remove for a minute and reinstall the battery on the hand unit.
Should reset to factory settings.
Best to you
Touch screen
micromax a27 pattern attempts
Samsung SGH A897 mobile touch screen not responding to touch Incoming calls are operable
Did you try restarting the phone...??? If it didn't work try resetting everything. And even if that is not working then I would say it's probably a hardware error. You would have replace your touch panel. Could cost you a little bit. Rush to nearest samsung service center and get it done.
And also bear to put a screen gaurd always. I would not advise you to use touchscreen phones without screen gaurds.
Good luck
Jun 23, 2011 • Cell Phones
When i touch the screen nothing happens , i cant open home or answer my incomming calls.
problem with touch screen
your mobile needs one of tow : -re install the mobile firmware if it doesnt work that means your touch screen needs to be changed
1helpful
How do I asswer an incoming call on my new Samsung Captivate Galaxy phone? Help me please!
Answering a call:
When a call is received the phone rings and displays the caller's
phone number, or name if stored in the Address Book.
1. At the incoming call screen:
• Touch and slide to the right to answer the call.
• Touch and slide to the left to reject the call and send it to
your voicemail.
• Touch and slide the Reject call with message tab upward and tap
a predefined text message to send to the caller.
- I'm driving
- In a cinema
- I'm in class now
- I'm in a meeting
- Sorry, I'll call later
- or -
- Tap Create new message to compose a new message.
You may also click on this link to download the user manual for complete instructions with photos:
http://www.samsung.com/us/support/downloads/SGH-I897ZKAATT
Note:
"Answering a Call" portions is on Page 46
Mobile touch screen problem
TOUCH SCREEN
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take care.
Jun 30, 2010 • Cell Phones
CAN NOT LOCK THE DEVICE
its not possible in this cell phone
Top LG Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
