Question about Health & Beauty
My FREERIDER ASCOT 4 mobility scooter is running out of charge after only a few miles. How many miles should I be able to get out of fully charged batteries?
Posted by Graham Lee on
Brian Gitei
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
For a good and well-functioning battery you will need to to go for 2years.
Posted on Sep 09, 2013
2 Related Answers
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: Battery full on Ascot Mobility scooter but wont start
mcdevito75 here, Double chek the connection at the battery and motor.
Posted on Jun 26, 2010
lennieg2000
  • 692 Answers
SOURCE: Freerider Ascot Electric Mobility Scooter
I would suspect the brake is not releasing correctly and dragging on the motor housing. Try driving the scooter a short distance and feel the motor case at the rear near the brake assembly if it is very warm or hot the the brake is sticking and will have to be replaced. Hope this helps
Posted on Jun 04, 2011
How can I fix This problem. after about 1.5 miles the scooter comes steadily to a stop. waiting for a few minutes it will go again Ok.
The motor is overheating. The service manual will tell you how to test. Pride has a service manual you can download from their website.
May 20, 2014 | Pride Go-Go Ultra X 4-Wheel
Quingo plus taking 30 minutes to power up and only lasts about 4 miles, when fully charged
Hi, can you please explain by the term takes 30 minutes to power up ?
Do you mean once you turn it on , it takes 30 minutes before it lights up ?
Regards
Rob
www.gewizrepairs.co.uk
Feb 28, 2014 | Pride New Mobility Legend 4 Wheel Scooter
Freerider mobility scooter
hi, okay there two things the batteries and the charger, can you try another charger ?
1. Batteries need replacing ?? make sure battery terminal connections are tight.
2. How long are you charging the batteries for ? i hear you say that's a silly question however you be surprised how many people charge their batteries for a hour then remove the charger.
3. Is the charger faulty ?
4. there is a remote possibility of a controller fault however this is not common..
In relation to the charger if you're in the UK, I offer a free testing service , you only pay the return postage...
Regards
Rob
Feb 02, 2014 | Health & Beauty
How many miles can I get from a fully charged Freerider Ascot 4 mobility scooter? My scooter seems to run out of charge after a few miles.
11 miles on full charged new batteries, this is approximately as condition change max distance, like you weight, if you are going uphill, how even the ground is etc. if you need more you could get a spare battery pack for it, and swap them over when needed. but remember to keep them charged even when not in use once a week is the best way to keep them in good shape.
Sep 09, 2013 | Health & Beauty
Freerider Ascot scooter will not work - battery fully charged - green light is flashing
Possible fault in the drive selector switch/ circuit or the motor. You can check the motor, test using a DC line to confirm. If so the selector drive is faulty. check the continuity and the DC drive feed to the motor. It is possible that the circuit is not working and so the board needs a check/replacement.
Jul 11, 2011 | Rider Toys
Freerider Ascot Electric Mobility Scooter (4 wheel) Battery charges and holds current - horn works and shows green on power dial Scooter hardly moves underload - the engaged lever is set correctly. I...
Jun 03, 2011 | Health & Beauty
I have a mayfair freerider scooter and all of a sudden it wont charge up. charger says abnormal charge. Is there something wrong wiyh the batteries or charger?
try borrowing a charger from a friend or neighbor to charge your scooter If it charges the batteries then your charger is bad if it doesn't charge your batteries then the batteries are bad Hope this helps
Apr 17, 2011 | Universal Health & Beauty
FREERIDER ASCOT 4 Had flat batteries which now have been replaced but still no power to the motors. is there any damage that can be caused to the electronics by the batteries going flat over a period of...
No or every unlikely.
electrics may be damaged from overvoltage or overloading the motor while it is stalled (steep hill) but not from batteries going flat.
Nov 21, 2010 | Health & Beauty
Jun 22, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Health & Beauty Logo
159 people viewed this question
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
