The ring count is determined by the voicemail system. The Edge 120 is a phone, not a voicemail system. What voicemail system do you have on your phone line?
The main box says Comdial DX 120.
What voicemail system is the DX-120 connected to?
There isn't a separate voicemail system. It's all integrated. The voicemail instructions just say Comdial.
If you're using the optional internal voicemail system, see page 381 of this manual:http://www.wedophones.com/Manuals/Vertic...
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
SOURCE: how do i inrease the number of rings
Don't know if this will work, but try the 983 feature, pw 1020000 (or 120000, or 10020000, depending on your extension numbering). Access the Mailbox menu. "Show" thru the menu until you get to "forward to" ###, then next. This should ask for delay. (to est time in seconds, multiply the number of rings by 6)
SOURCE: change number of rings
To change # of rings you have to go into programing OK press feature * * on the main set and config (266344) then the password admin (23646) this goes to terminals and sets hit show and enter the set you want to change go to capabilities this will allow you to chang # of rings on that set
SOURCE: My phone on our Norstar system rings & rings
Fress F985 u will get voicemail DN. Note down ur voice mail DN.
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.Press show then change put the voicemail Dn which u had written then next.
Now call will go to ur voicemail provided u have ur own presonal mailbox. If it is not there u will have to createe it otherwise it will go to general delivery mailbox.
Hope it will be helpful for u.
Thanks.
SOURCE: how do i change the number of rings on my phone
The change is made in the voicemail system, not the phone. Get in to your voicemail box, listen to the menu and select the option for 'setup', 'settings' or 'system options', the exact name varies according the voicemail system, and you usually have to make several choices, but the options are almost always availble with menu selections. With hundreds of voicemail systems available, that's about the best advice you'll get with the information you provided.
This was supposed to be attached to Comdial Vertical Edge 120.
