One For All URC-3445 Remote Control Logo
sudhakaranMeleveettil Posted on Sep 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is writing FACTORY on the top of screen. how can I remove this
Level 3:
Top Expert:
  • One For All Master 76,851 Answers
  • Posted on Sep 10, 2013
One For All Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15004616
Points
237762
Your TV has been entered to Factory mode [Service Mode] by anyway. In this condition, only limited buttons on the remote will work. To make it right, you have to exit this mode, and come back to normal mode. To get more details about how to get into and exit from service mode [Factory mode], check this site. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
  • ravindra singh Mar 06, 2015
    Need help oskar tv 53 in pro.factory bosv 100308v3
tip
SERVICE MODE AND POWER FL PANEL CIRCUIT
1. Main Functions
• Diag
Performs unit test of devices installed on the board.
• Display Error Log
Error log is displayed. Displayed contents can also be saved in an USB memory device.
• Factory Initialize
Restores the unit to its factory settings.
• Network
Checks the wired network connection.
• Version Up Not used.
• System Information
Displays the system information of the unit.
Displays information such as the software version, drive information, etc.
• EMC Test Mode Not used.
• Drive
Write drive OP data and check drive.
2. Menu Tree
3. Service Mode Menu (Top Menu)
This is the top menu of service mode.
Each function is accessed from this screen.
Operation:
[1] Moves to Diag screen
[2] Moves to Log screen
[3] Moves to Factory Initialize screen
[4] Moves to Network screen
[5] Moves to Version Up (DISC version update) screen (Not used)
[6] Moves to System Information screen
[7] Moves to EMC test mode screen (Not used)
[8] Moves to Drive screen
[9] Moves to HDD mode (Not used)
[UP]/[DOWN] Moves the cursor [ ENTER] Moves to the screen of the item selected with the cursor.
FOR MORE CHECK THE LINK ...
Electronics Equipment Repair Center
2answers
Can you reset the tablet?
You can reset your Android phone or tablet normally from its Settings screen. Tap the Backup & reset option on the latest versions of Android or tap Privacy if you're using Android 2.3. Tap the Factory data reset option and to through the reset of the steps to confirm the Help on writing a college scholarship essay factory 1 Scholarship Admission Essay Writing Expert Regina Canada
How i recover my infotmic tab
Depending on which version you have please see the following notes:
How To Factory Reset/Recover the systerm On Your Tablet PC(Flytouch 2/SuperPAD 2/Infotmic tablet 2)
1. Press "Power" and "Home" button at the same time, hands off until you see the words on the screen.
2. Select:"wipe data/factory reset" with the "volume" button, and then press "menu" button.
3. Select:"Yes -- delete all user data", and press "menu" button.
4. Wait until you see" Enter erase_cache Data wipe complete" .
5. Press "reset", calibrate it and set the language.
How To Factory Reset/Recover the system On Your Tablet PC(Flytouch 3/Flytouch 4/SuperPAD 3/Infotmic 3)
1. first press the "MENU" key, keep pressing the "MENU" key while you press the "POWER" key, remove your hands when you see "recovery" from the screen.
2. Wait a few seconds until it is done. And then the system will start..
Precautions
A power failure during the firmware writing operation may disable the tablet PC.
* Use a fully charged Battery or dedicated AC Adapter for the firmware update.
* Do not shut off the power during the firmware writing operation
I factory set my laptop now it will not work I get a blue screen with writing on but can't read it I can not use safe mode as this will not allow me to reload my factory settings any idea
ok first need some info like what brand and model # of your laptop if there is more than one stick of ram you could try removing one then try it if nothing take out the other stick and replace the one you removed first.
Restore factory settings
start up computer and immediately start tapping f10. This will take you to a black screen with white writing. Hit enter. The next screen gives you two options- hit the skip button. Next screen check the box and hit next. Your computer will be restored to it's factory settings in about 20min. Make sure your computer is plugged in.
Writing on the screen is fuzz. can this be adjusted to sharpen the writing?
On the rear of this TV...if it is an RCA....there are two potentiometers. You do not have to remove the back cover. The top button is your focus. Try not to move the lower button as this is your screen voltage! Mark either of these with a permanent marker first, so you can return to the original setting. All other TVs, please remove the cover and use great caution to perform your focus!
1helpful
Nintendo DS behaving erratically-Screen malfunction????
Normally replacing the touch screen will fix these types of problems. Please note that there are two screens on the bottom and not just one. You have the touch screen and under that you have an LCD screen just like the LCD on the top. You will have to remove the touch screen from the LCD as it has double sided foam tape holding them together. Also, the small clip that holds the ribbon cable to the board is easily broken, so be careful with it. If you break it you will not be able to get the ribbon cable to stay in and the touch screen will no longer work and your DS will likely not stay on.
Black line at the top of tv
MUTE 1 8 2
or
MUTE 1 8 3
Look for vertical adjustment
Be careful, no factory reset if you screw up
Write down old value before adjusting
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
