Try to use external speaker. connect it where you usually connect your head and check if it work . If ever the external speaker will work it only means that the problem is your headset ( defective )If in case the external speaker will not work it means the problem is the terminal ( the port where the headset or external speaker connection )
First, check if you put the connector for external speakers all the way to the end. Sometimes when the connector isn't fully inside both internal and external speakers will work. After you do that, once you connect the external speakers, go to the sound settings in windows and look for the volume mixer. You can regulate the sound for each type of speaker there.
Hi, I understand that external speakers are working but internal speakers are not working on your laptop.
This could be due to the socket you are using to connect external speaker. if the socket's inside contacts looses the contact it cannot internal speakers.
Thanks,
Shiva
check your sound / speaker settings in the control panel .. ensure that it is set to laptop stereo speakers and not external ... if you want external speakers ,, ensure you have the speakers connected to the green port .
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Most PCs and laptops have an audio out jack, usually colored light green. Most external powered speakers have a 3.5mm mini plug that goes into this jack, usually found at the back of the case, or both at the front and back (for PCs), or somewhere around the sides, or at the back of your laptop.
You may control sound volume from your PC, while setting the volume close to the highest on the speakers, or the other way around. Your choice.
On acer laptop you have already speakers. but you want to connect external speakers then please find that three conector in your laptop and connect you external speakers on one of them. please try each connector and you are able to connect external speaker.
