Washing Machines Logo
Posted on Sep 14, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ariston a1435 Washer starts cycle for washing but then the drum does not turn. Ifi put the unit into a spin cycle the drun unit then works fine . just doesnot work in wash cycle
  • gcoupe Sep 15, 2007
    Hi I did this and did 1 wash on No 8 (cool) seemed ok but it appears the motor looks like it labours. I started a Hotter wash on No4 today untit filled but drum did not rotate. I reset unit again as per you advice and now started a warm wash again on No 8. It appears to work but the drum does seem to labour in rotation. Could this be the brushes on the main motor ?
Anonymous
Level 3:
Master:
Sergeant:
  • Master 461 Answers
  • Posted on Sep 14, 2007
Anonymous
Master
Level 3:
Master:
Sergeant:
Answers
461
Questions
0
Helped
109758
Points
1238
Does it work before? Try reset the machine... 1.0 Turn off the machine. 2.0 remove the power supply from the main supply. Leave the machine without any connection for about 15 minutes. try again?
  • Anonymous Sep 18, 2007
    Yes please check them.
2answers
The washing mashine goes through the complete cycle but only starts the drun rotation every time the wash cycle comes and than after the apropiate time continiues through the full cycle without the timer?...
I hope you can explain once again the fault that is noticed as I am not able to judge what you have experienced.
If the DRUM is not rotating or is erratic in the cycle then it is possible that the program controller unit is a prime suspect.
The power to the drum motor seems to be erratic from the controller and so is making the drum turn out of turn. I thin when the controller is activated the drum rotates without a problem.
So please check your program controller unit.
1helpful
Ariston A1435 washing machine. The prgrammes do not move on.Can select any cycle it washes but stays on the programme and does not move onto the rinse cycle have to manually stop and select rinse and spin....
If the program is put ON does the inlet valve open to let water IN. If so does it after the water is filled to the set level go to wash If yes , then after wash does it drain ? If all the above cycle is true then the program is working correct and a fault in the input can be the reason.
If however there is distruption of the sequence, then each input and drive must be checked to establish if the program controller or the input sensors are faulty.
Please give me a feedback
Very loud banging and clanking when the drum is spinning
If the dryer is making this noise the roller on the belt tensioner has a flat spot causing this to happen. The roller and belt are replaced as a unit. If it is the washer unit the spring has fallen off on one side of the drum which is one of two that balances the drun while spinning
1helpful
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
1helpful
Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
10helpful
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Problem tripping GFCI
GFCI units go bad with regularity , I would replace it first.
washer manufactures usually put the schematic inside taped to a side panel.
open the top panel and see if you see a plastic bag along the sides.
the site for this washer did not have any info or manuals online right now.
Ariston A1435
Usually there are two windings for washers, One goes forward and one reverse, either one is bad OR: There is also a transmission in washers that when washing; they agitate the load when spinning; they, well spin! (ha) If it wont wash then there is either an internal component in the tranny bad or a solonoid that has gone out. Take the cover off and check to see if the belt is ok as well. Let us know :-)
Washer not completing cycle
I HAD THE SAME PROBLEM ON A 4 MONTH OLD MACHINE AND I CALLED A SERVICE PERSON. HE SAID THAT I CAN THROW IT AWAY. THIS IS A PROBLEM THAT NOBODY CAN FIX.
Top Washing Machines Experts
Marvin
Marvin
john h
