SOURCE: PS2 Power Ribbon
you need to replaced the ribbon cable go to www.repairmyvideogame.com they have the parts for $1.00
SOURCE: PS2 power ribbon Help!!!!!!
Use a pair of needle nose pliers and grip the connection end of the Ribbon cable by the hard plastic piece. Insert this cable in the second connector from the front. The connectors are located under the right edge of the CD drive.
Hi Anishpp
If it came loose from the buttons, you need to remove the button holder to get to the connector. Push he ribbon into the slot on the back of the buttons.
If it came loose from the motherboard, you will have to remove the guts of the PS2 to see the connector under the cd drive right side. This is done by removing 4 screws. Two are on either side of your Controller ports. Another one is located between the fan and power block. Another is to the left of the powerblock. lift the guts from the back and pull the system out. looking at the right side, plug the reset Eject ribbon into the 2nd connector from the front. Then put it all back together carefully.
