Refrigerators Logo
Question about Refrigerators
DEFROST SEEMS STUCK
THE FREEZER ON OUR GALLERY SERIES, IS COOLING LIKE REFRIDGERATOR, AD THE REFRIDGERATOR IS NOT COOLING AT ALL. I WAS WONDERING IF THE DEFROST UNIT IS STUCK ON, AND IF THIS IS THE PROBLEM, 1. HOW DO I UN STICK IT, AND2. HOW DO I TELL IF THIS IS THE PROBLEM?
Posted by Gary Gittelman on
Anonymous
    Novelist:
  • 87 Answers
Do you have ice at the back of the freezer section. If you do defrost the unit and see if this makes a difference to the performance. If it behaves you probably have a defrost heater or defrost thermostat fault. If it fails to pull down you possibly have a fan motor gone or a problem with the defrost circuit. I would suggest if it behaves monitor closely and if it fails contact a good fridge guy who should be able to diagnose which fault it is. Hope this is of some help.
Posted on Sep 15, 2007
1helpful
My Amana refridgerator does not cool but the freezer works
If you have noticed a rise in temperature in the fridge, and there seems to be fromst building up in the freezer than your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
6helpful
Freezer side works, other side does not cool
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you ti figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
2helpful
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
DEFROST SEEMS STUCK
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
2answers
HELP!
2answers
Refridgerator not cool enough.
sounds like the probable cause is defrost heater. get someone to test the element.
Open Questions:
Top Refrigerators Experts
Gil Shultz
john h
