Tomtom GO 700 GPS Receiver Logo
Question about Tomtom GO 700 GPS Receiver
Tom tom go 710 for auto
Was working fine. turn it off to go inside for a few hours came backturn it on and got littles hands pointing to the sim card pleas help thank you
Posted by neck on
  • neck Sep 13, 2007
    what can i do to fix this problem
  • A D J Dec 09, 2007
    I used the unit for about two hours, turned it off. After four hours tried to turn it on and the unit wont come on. It has full charge but still wont switch on.
Anonymous
    President:
  • 4,402 Answers
STEP 1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Posted on Jan 22, 2008
Is a 8gb sd card ok for my tom tom go710
I understand that the largest memory card that can be used in the 710 is only 2gb -
BUT it has to be an SD card not an SDHD card, otherwise it won't work!!
Hope this helps
TRIED TO UPDATE MY TOMTOM GO 710 BUT NOT ENOUGH MEMORY BOUGHT NEW CARD BUT TOM TOM WONT TAKE IT TRANSFERED DATA BACK ON TO OLD CARD BUT TOMTOM WONT TAKE THIS...SHOW TWO CROSSED HAND ON MEMORY CARD...
Just had the same problem..............
I discovered that you must only use an SD card and not an SDHD card.
I bought a bigger SD card (2Gig), installed it and copied the data I wanted without any probs. With the SDHD card I couldn't transfer anything and didn't get any help as to why...(there's a lot to be said for trial & error).
Hope this helps
I HAVE A TOM TTOM GO 710...DOES IT NEED A SIM CARD
yes, the tomtom 710 needs the sd card which has the maps on it. if you just bought it and didnt get one with it, i suggest you take it back, because the cost of the card often out weights the value of the gps.
if you want to buy a sd card for it, you can get one HERE on the tomtom site or you might want to try ebay.com which sometimes they have them...i just checked ebay for you and currently there are none listed.
7helpful
2answers
Tom tom won't turn off
if it does not proceed when the icon is selected, presume data corruption or in fact no data.
TomTom is renouned for this type of problem.
try rteinstalling the map data from the source.
try a reset first ( small pinhole on rear) put open paperclip end in and gently push the button inside) if this still fails then data installation is the go
4helpful
2answers
I have a tom tom go 710 and need to know how to reset it, and when i turn it on, the screen shows that I need to install SD card. I am wondering if I need the SD card for it to work properly?
To reset your TomTomGo710 device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
tomtom go710 map data is on SD card without it, it will not work.
2answers
My tom tom one has lost its voice
From the main menu tap preferences.
To change the volume, tap Volume preferences in the Preferences menu. You will probably see a little "speaker" icon with an X through it. Tap this to turn the sound back on.
To change the volume quickly while you are driving, tap the bottom left-hand section of the Driving View and move the slider.
To change the voice, tap Change Voice in the Preferences menu.
Garmin 710 Doesnt show all the maps
Garmin maps are married to the device they were bought for. You should not be able to take an SD card from one and have it work in another. Another point is, was the 710 already registered to someone else and never deregistered? Have your registered the 710 and does it show up on your Garmin account?
If the 710 is not on your account, Run Garmin Express (download from Garmin). Connect the 710 to your PC. Any maps that the 710 is entitled to will show up in Garmin Express. You may have to buy the map on Garmin if the 710 never had it before.
2answers
Recently after working one day the next day when i tried to use mt tom tom 710 it wouldnt switch on but the mains light was lit when plugged into cig lighter
Try giving it a full charge. I used different model Tom Tom that would not turn on even if plugged in until after the battery was recharged.
Help
Hi, i did the same thing with my tom tom 300 go, i fixed it by borrowing my mothers sd card from her tom tom 710, i put the card into a card reader and copied the hole card to my computer then copied it back onto my sd card out of my tomtom then put in mine and bingo it worked with all the fetchers that her tom tom had and the updated maps it still said it was a 300 but had the 710 stuff try this it worked for me it should work for you.
Tom Tom Go 710
leave on charge for two hours, then with the SD card out hold down the reset button at the back of unit for ten seconds and then the 'on' switch for ten seconds.
Top Tomtom GPS Experts
Marvin
Marvin
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
