Question about Lands Phones
The problem is; you don't know what to do when the refrigerator is freezing, and don't want to call a repair service technician to pay for the proper (and efficient) fix when the solution is outside the expertise of home handyman - who doesn't know a lot about your refrigerator.
Posted on Mar 08, 2018
SOURCE: ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Posted on Aug 23, 2008
SOURCE: GE Profile Knocking
Unplug and closely examine the area for a loose fan blade or anything that may be causing the noise. Better now than to get damage that could be prevented. Let me know what you find, Thanks, Sea Breeze
Posted on Mar 23, 2009
SOURCE: The refrigerator temperature keeps dropping
I had the same problem with my GE GSS25LGMB and after some googling I learned that the damper door might be broken. Indeed after I took off the damper assembly the door appeared to be broken at the hinge. This door has its own thermostat and controls the influx of cold air into the fridge which explains the frozen food. I am trying to glue the broken piece back on. See if it works. Othwersie you'll have to replace the entire damper assembly which costs about $91. (http://www.pcappliancerepair.com/cgi-bin/detail.cgi?item=WR49X10091&brand=GEH)
Posted on Apr 28, 2009
SOURCE: GE side by side keeps frosting up and fridge is not very cold
It sounds like you have a defrost system problem. most commonly its your defrost heater on most GE ref. It can be located by removing the back panel of the freezer. If you remove the heater it can be tested for continuity at any parts distributor. I would also look for the quarter sized thermostat mounted at the top of the coils to see if it looks "popped" at the top. If it is then replace the thermostat. Hope this helps MJ
Posted on Jul 28, 2010
SOURCE: our GE Side by Side Eterna Refridgerator, keeps
change thermostate switch
Posted on Dec 01, 2010
