Question about Siemens SpeedStream Modem (4100) (SS4100)
I have siemens speedstream 4200 modem but i am unable to connect it to my bsnl broadband line while my earlier old modem is working but its faulty now. please help me how i can connect this new modem
5 Related Answers
shaky120
John Anderson
  • 310 Answers
SOURCE: 4200 speedstream modem problem
I guess you probably aint set-up a wireless router before, what you need to do is get it connected up so you revieve local area is connected then, load internet explorer you will recieve a message like page not displayed. where you usually type in www.ebay.com for example type in the number thats on the bottom of the router ie it looks somthing like this 192.168.1.1 for example. a menu will then appear, fill in your broadband username details etc and you should be up and going, if you have problems feel free to email me,, All the best John [email protected]
Posted on Feb 28, 2007
Anonymous
  • 36 Answers
SOURCE: Siemens Speedstream 4100 Modem manual installion
* You dont need any special drivers to install modem.
* Open up internet explorer, type 192.168.0.1 in the address bar and press enter key.
* Now you should see the configuration page of modem.
* On the left side, click on Advanced button, below that, you will see "connection configuration" option - click on it.
*** If it asks for modem access code anywhere, you can find the code underneath the modem. please type it ***
* Under this page, you have to enter the email address in username field and password, change the connection type to smart keep alive, click on save changes
* Now it may ask you for restart modem. click on restart. within 1 min, you will be connected to internet.
Take care
Posted on May 26, 2008
Anonymous
SOURCE: siemens ADSL Modem(model- C2110)
siemens c 2110 modem 3 lights flasing continously what to do
Posted on Jun 08, 2008
Anonymous
SOURCE: Speedstream 4200 setup
To configure my siemens 4200 modem I enter 192.168.254.254 into the address bar of the internet browser. You should get a login screen that ask for your user name and password. Default user name should be admin and the password should be admin. I hope this helps you
Posted on Aug 20, 2008
Anonymous
  • 158 Answers
SOURCE: unable to set up internet connection - option greyed out
in order to connect to internet you require a username and password
that user name and password will be given to you durin first time installation if you dont remember the username and password call up your broad band help desk. they will help with the user name and password.
if you are aware of the user name and password ,
you need the configure the internet setup using the user name and password
i ll give the steps to configure the user name and password in windows XP operating system
1 click on "start" button at bottom left of your desktop
2 click on control panel
3 on left hand side of the window click "classical view"
4 then click on the icon network connections
5 there you will find "create new connection"  or "new connection wizard"on the left hand side just   double click on it
6 a new dialog ll appear click next
7 on the next screen select "connect to internet" and click on next
8 on the next screen click on "setup my connection manually" then click on next
9 on the next screen select the option "connect using a user name and password" and click next
10 you will be asked for ISP name "for eg:fill in AT&T"
11 on the next screen you willlbe asked for user name and password , fill in the respective details
for eg: sam @att.net :username
            ******** :password
12 den click finish
you will find an icon in the desk top by now. just double click on that icon and try browsinn
you must be up and runnin ! ! !
Posted on Oct 01, 2008
No activity on my new speedstream 4200
Ethernet and DSL lights are indicating you have ADSL available on your line, and that you have computers connected to the router.
What has probably happened is that Optus did not set up the new router with your username and password. Go to thw following website for details on how to setup the modem.
http://help.optuszoo.com.au/help/dsl/connected/windows/optus_modems/speedstream_4200
Manual Modem Settings The Optus DSL Broadband self-installation CD configures all the necessary settings for your DSL Broadband service. You do not need to manually configure your modem if you have run the self-installation CD. While the following information is provided for your reference, using the self-installation CD is the recommended method for configuring your modem.
The Siemens SpeedStream 4200 ADSL modem can use either USB or Ethernet to connect to your computer.
  • If you are connecting via USB you will need to run the self-installation CD to install the USB driver before you connect your modem. The Siemens SpeedStream 4200 ADSL modem supplied by Optus has been customised for the Optus DSL Broadband service. Only the USB driver supplied on the self-installation CD will work with the Optus service. If you do not have the self-installation CD, you can download the latest drivers from the Siemens website.
  • If you are connecting via Ethernet it is possible to manually configure your modem without the self-installation CD. Only a web browser is required.
After connecting your modem there are two key steps to manually configure your modem for the Optus DSL Broadband service:
  • PC settings - Configure your computer's Ethernet network interface.
  • Configure Your Modem - Set the password in your modem's configuration pages.
top
PC Settings Step by step instructions are provided for each of the supported Windows operating systems:
  • Windows 98/Me
  • Windows 2000
  • Windows XP
  • Windows Vista
top
Configure Your Modem To configure your modem settings you must now access the configuration manager using your web browser. This is done by entering the IP address in the address bar of the browser window as follows:
Note: If you are updating the password in your modem, please complete steps 1 to 3 only.
Step 1 of 5
  • Enter http://10.1.1.1 (Default IP address of the Optus Supplied Siemens SpeedStream 4200) to access the modem Configuration software. You may wish to add this page to your Favorites for easy access later.
  • The following modem System Summary screen will appear.
ss4200_home_disconnected.gif Step 2 of 5
  • Click on the word Setup in the green menu of options on the left side of the web page. An expanded set of options will be displayed.
  • Click PPP in the list of options that appeared below the word Setup.
  • The ISP Password page will appear:
  • Replace the default username ([email protected]) with the username provided for you by Optus DSL Broadband.
  • Replace the default password with the password provided by Optus DSL Broadband in the Password field.
  • Note: You will find your Optus DSL Broadband username and password on the letter you received with your self-installation kit.
  • Save these details by clicking the Save Settings button.
Step 3 of 5
  • The next screen will ask you to disconnect and reconnect to the Optus DSL Broadband service.
  • Click the link to return to the System Summary page.
  • Click the Disconnect button to disconnect the modem from the Optus DSL Broadband service. The text on the button will change to Connect.
  • Click Connect to reconnect the modem to the Optus DSL Broadband service.
Step 4 of 5
  • Click the word Mode in the green menu of options on the left side of the web page.
  • Confirm that Optus Bridge is the selected operation mode.
  • If Optus Bridge is not selected click the radio button next to Optus Bridge to select it.
  • Click the Apply button.
  • Click the Reboot button to restart the modem using your saved settings.
  • After about a minute the modem will return to an operational state and connect to the Optus DSL Broadband service.
ss4200_reboot_3.gif Once the modem has rebooted and the ADSL connection has been successfully established the DSL LED indicator will light steady green.
Your modem is now connected to the Optus DSL Broadband service.
Jul 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Siemens speedstream 4200 modem need any driver?
http://gigaset.com/shc/0,1935,us_en_0_14791_rArNrNrNrN,00.html GO HERTE RICHARDM69
Nov 18, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Configure gigaset SE587 for BSNL broadband
If this is router is gifted to you by a friend of yours who is from UK, Please check if this is locked. Most of the times these would be locked by the ISP. This is a router provide by tiscali UK. Please select the dialing number to 0,38 this is the dialing code for india.
If you use this should work and use 192.168.1.1 as default DNS.
Oct 30, 2008 | Siemens SpeedStream 2624 (SS2624) Wireless...
Speedstream 4200 dsl modem
If you will have the new modem and the same problem will occur, then you can say that it could be a fault with the phoneline or if it is with the old modem.
May 19, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Siemens ADSL Modem(model- C2110)
Mar 08, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Setup Siemens 4200
u need to get an installncd from them or at least the manual install setting so that you can manually configure your computer.
Nov 23, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
I have just set up 4200 with dsl - you may find that you need to reset modem before you can configure. I was told that you need either a grey or yellow cable from your laptop to the modem. I use 10.0.0.138 to access modem. The 4200 I have was from a bigpond a/c - originally configured accordingly.
Regards,
Richard
Nov 12, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Connecting to xbox live
log into modem using 192.168.2.1 in your browser and go to modem utility through browser.
then select last option on left of utility screen on left and choose reset.
this will reset modem to factory settings.
then call microsoft support there is a toll free support number in yellowpages.ca. ask them to help you setup pppoe connection in the xbox. you can set the mtu setting there also to 1492 for dsl broadband and if on cable use 1500
Aug 11, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Cant connect my router
what is the source of your connection thru telepon line or a broadband connection or DSL?i need to know this........
Jul 16, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Siemens SpeedStream Modem (4100) (SS4100) Logo
Top Siemens Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
