Alpine CDA-9807 CD Player Logo
Question about Alpine CDA-9807 CD Player
Alpine cda 9807 in yukon xl
Plays music with key in aux and on position but when started ,nothing
Posted by david morin on
Anesh Vassan
    Scholar:
    New Friend:
  • 71 Answers
Hi david, check out the connection of the yellow and red wires on the back plug. yellow must be connected to a direct battery positive line(continuous positive), the red must be connected to a live wire from the ignition switch OR from a point that is +12v live once the car is started(switched positive). also make sure that that the ground connection is a direct good connection to the body of the vehicle!! make sure that the remote wire(blue) is insulated if you not using an automatic aerial or external amplfier. good luck.cheers.
Posted on Sep 08, 2013
Testimonial: "checked and rechecked those connections but the stock radio had speedcontrol and onstar and wondering if need a bypass loop on speed control or audio interupt"
5 Related Answers
Anonymous
  • 790 Answers
SOURCE: alpine cda-9807 no voice when cd plays.
hi
Try to set the cd function to settings! or menu, maybe you have not fair settings in your unit!
Thanks!
Posted on Sep 23, 2008
Anonymous
SOURCE: Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Posted on Nov 06, 2008
Anonymous
SOURCE: instaling alpine car/cd stereo cda 9807
how do i install my alpine cda 9884 ...on a 92 caddi
Posted on Nov 18, 2008
Anonymous
  • 77 Answers
SOURCE: On my Alpine CDA 7892 i have the aux cables right
I believe you need the Alpine KCA-410C - Ai-Net multi-changer/versatile link adapter before you can input from an external source directly.
Posted on May 08, 2009
Anonymous
  • 12 Answers
SOURCE: I have an alpine cda-9883 cd won't eject & error
try detaching the "face" and there should be a little button that you can only push in with some kid of really thin stick,maybe a pin that will reset the cd player and hopefully work
Posted on Dec 15, 2009
Aux wont work
check the devices volume level. I had the same problem with my phone. Every time i plugged it in the phone volume level would go down to about half way. hope this helps
Cda-9807 owners manual
Goto the below link http://www.alpine-usa.com/
and goto Tech Center/archived manuals
3helpful
HOW TO SET THE TIME ON ALPINE 9807
Hello! In clock priority mode...Press and hold the Disp/Title button for 3 seconds, The time indicator will blink...Turn the Rotary/Encoder to adjust the hour...When hour is set, turn the Rotary/Encoder to adjust the minutes...Time is set for 5 seconds after the minute...
Guru............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Trying to play Ipod through my Alpine cda-9811
you need to set up your system to accept aux. this means you will need to set the 'aux on', as the default setting is 'off'. use the manual and refer to page 23 & 24. please read the instructions carefully, as they are slightly confusing.
5answers
Alpine cda-9807 no voice when cd plays.
hi
Thanks!
No bass thru cd player
it seems like you connected the wrong remote wire to the amp.
Alpine has two remote wires.
BLUE (only) This is the pwr antenna remote wire,every time you insert a cd this remote wire,the pwr cut out.
BLUE/WHITE STRIPE This is the AMP REMOTE WIRE,THIS IS THE REMOTE WIRE THAT YOU NEED TO CONNECT TO THE AMP
LET ME KNOW IF IT WORKS
thank's
2answers
Instaling alpine car/cd stereo cda 9807
Its probably your wiring harness that came with the stereo. Which can cause many more problems. alpine changed their wiring harness around that time. But they used the same plug, just wired different. So now there are crossed wires, but the plug fits, causing the amp chip to fry. maybe even further than the amp chip. an amp chip replacement runs about 80$ at a repair shop. if its just that.
A.M. stations
What type of vehicle is it in? Some manufacturers, such as Toyota, use separate antenna plugs for AM and FM that cannot be plugged into an aftermarket unit at the same time.
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
