The monitor was dropped and now simply flashes different colors on a rotation. In order, it shows black, white, gray, then a multi-colored screen. The multi-colored screen has 4 horizontal colored lines, from top to bottom they are red, green, blue, and white. The monitor seems to be stuck on this rotation and none of the buttons on the remote or face play seem to do anything.
SOURCE: about colors
It sounds like either an internal wire is loose, or possibly in the connector to your video cable. Make sure the connections for your video cable are tight both at the computer and at the monitor. If they are, try a different cable (cables are much cheaper than monitors, always start with the easy solutions first). If the problem is internal to the monitor, then it is up to you to decide whether to try to diagnose/fix it yourself, or buy a new monitor. The cost to pay someone else to fix it is likely more than the value of the monitor.
SOURCE: vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
SOURCE: Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
SOURCE: i have a blue line in my monitor
line driver element defective. no repair possible, to my knowledge. replace LCD or ignore line.
