SOURCE: Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
SOURCE: D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install
http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=2300&DwnldID=17268&url=/17268/eng/iata87enu.exe&PrdMap=&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
pls rate me FIXYA if ur problem is resolved
SOURCE: Hi I just finished building my
This is because you either don't have any windows loaded or else the hard disks are not being recognized by the system.
otherwise if windows is present then the MBR Master boot record is damaged.
try reinstalling windows.
SOURCE: xp could not find sata hard disk
the driver is not included in the driver cab on the xp and server 2003 disks, you will need to download the drivers and put them on a floppy disk (usb floppy if you do not have an internal drive) then as the blue setup screen is loading press F6 to load the drivers.
SOURCE: Sata ports & mic is not detecting
lack of earthing in the power supply does cause hardware failure. Kindly check the earthing.
Regarding your mic and hard drive, I think you need to replace it with a new one.
Better get it reviewed by an H/W engineer.
Peace!
