Question about Stanley 77 500 Intellilaser Pro Stud Sensor & Laser Level
Lost directions for stud sensor BDL153S - Stanley 77 500 Intellilaser Pro Stud Sensor & Laser Level
Instructions
Here's is a link to the manual for download - direct from Stanley.
May 22, 2013 | Stanley 77 500 Intellilaser Pro Stud...
Need torque scecs for control arm
1) Install or connect the following:
  • Lower control arm
  • Control arm bolts and nuts
  • Ball stud to the knuckle
  • Ball stud castle nut, tighten the ball stud castle nut to 22 ft. lbs. (30 Nm), plus 135 degrees
Note: Do NOT loosen the ball stud nut in order to align the ball stud nut slots to the ball stud cotter pin hole. If necessary, tighten the ball stud castle nut in order to align the ball stud castle nut slot to the ball stud cotter pin hole. Ensure that the cotter pin ends do NOT contact the ABS wheel speed sensor, the ABS sensor connector or the drive axle.
  • NEW cotter pin and bend the ends
  • Stabilizer shaft link
  • ABS wheel speed sensor jumper harness to the harness retainer clips
  • ABS wheel speed sensor connector
    • Lower control arm nuts, tighten the lower control arm nuts to 71 ft. lbs. (96 Nm)
    • From Chevrolet web site.
Jan 30, 2013 | 2005 Chevrolet Uplander
Red light doesn't go off on stanley studfinder
Hi Laurie,
I think you might have confused the calibration set up in the first step of the directions. This must be done each time the unit is powered on, placed on a different wall, or whenever it is providing ambiguous indications. For you convenience, I have pasted the operation manual below. You should download and review the entire manual - free of charge here.
1) Hold the Stud Sensor 50 flat against the surface making firm contact.
2) Press in and hold the activation button. The green
and red LED's will light. When the red LED goes off,
the unit is calibrated
. Keep holding the activation button
during all of the following procedures.
Note: While calibrating, the Stud Sensor 50 must not
be placed directly over a stud, dense material such as
metal, or over a wet or newly painted area, or it will not
properly calibrate. If the Red LED stays lit, move to
a different location and try again.
2) Slide the Stud Sensor 50 slowly across the surface
in a straight line. As it detects a stud edge, the red LED
will go on.
Use the handy pencil notch located at the top of the
unit to mark the stud edge.
3) Repeat the above steps from the other side of
the stud. Coming from the opposite direction, mark
the other edge of the stud. The midpoint of the two
marks indicates the stud center.
Cautions on Operating
The proximity of electrical wiring or pipes to the surface
of the wall may cause the Stud Sensor 50 to detect
them as studs. You should always use caution when
nailing, cutting or drilling in walls, ceilings and floors
that may contain these items. Always remember that
studs or joists are normally spaced 16 inches or 24
inches apart and are 1-1/2 inches in width. To avoid
surprises be aware that anything closer together or of a different width may not be a stud.
I hope this helps & good luck!
Aug 18, 2012 | Stanley 77-050 Stud Sensor 50
How to operate the 077445, I have lost instructions
You can view a manual for this product at
http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-552007645425770921/!DOWNLOAD?entryid=156229&attachid=19306
Or visit http://server.iad.liveperson.net/hc/s-44183334/cmd/kbresource/kb-8342273085529316507/front_page!PAGETYPE?category=2 and type 77-115 into the search box.
Mar 07, 2011 | Stanley 77 115 Intellisensor Plus Stud...
Not sure how it works - looking for instructions
Hold the stud sensor against the wall where the wall sounds hollow (no stud at this location). Hold the button down while you slide the unit horizontally. When it moves over a stud, it will give you a solid beep and the display will show you a solid vertical line. If it starts beeping intermittently, you may have started over a stud which will cause an error.
Do not lift the sensor off the wall when you slide it as this will also cause an error.
Jan 19, 2011 | Stanley 77-720 Stud Sensor 200
I need calibration instructions
This unit is self calibrating. There is no method for manually calibrating this tool. Just hold the sensor flat against the wall and depress the button. After a few seconds the unit is calibrated and you can begin sliding it smoothly across your wall to detect studs and wires.
Dec 29, 2010 | Black & Decker BLACK DECKER BDL153S Stud ...
Tring to replace the valve cover gaskets and would like a little more detail instruction on part removel.
  1. starting with the RIGHTside valve cover, disconnect the crankshaft sensor connector then the a/c compressor connector and the ac cycling switch connector.
  2. release fuel preasure and disconnect lines. remove the connections for the fuel injectors and the ignition coils,remove the pcv tube and move of to the side,
  3. remove the evap purge valve and repostion the holddown clamp for it,remove the bypass tube.
  4. disconnect harness from valvecover and postion out of the way, now remove the studs,nuts and valve cover .REVERSE DIRECTIONS TO INSTALL,
  5. NOW LEFTSIDE.
  6. Remove oil sensor connector, next remove the brake booster asmbley.
  7. remove cylinder head temp sensor jumperwire connector.
  8. remove bolt and to studs for power steering resivior and braket and sit aside.
  9. disconnect camshaft sensor connector.
  10. disconnect connectors from coils and injectors,
  11. remove the wiper cowl and then the42 pin connector and 16 pin connector and trany connector.
  12. remove the 6bolts and 5 studs from valve cover and off with the cover, rev directions to install.
  13. NOTE; CLEAN VALVE COVER AND HEAD SURFACE WHERE GASKET WILL SIT, THEN APLLY THIN COAT OF SEALANT TO COVER AND PUT GASKET ON AND LET SIT FOR 5 MIN, THEN APPLY THIN COAT TO GASKET TO MATE WITH HEAD. .
HOPE THIS IS HELPFUL, GOOD LUCK AND HAVE A NICE DAY.
Nov 28, 2010 | 1998 Lincoln Continental
Trying to hang gatco channel towel bar. there are no studs what size hole should I drill? I lost my directions.
Go to Home Depot, hardware or Plumbing isle,, tell them you want to hang a towel bar and you want some self drilling wall studs rated larger than or equal to 10 pounds. bring one of the screws from your Towel bar kit.
Nov 28, 2010 | Gatco & Channel& Satin Nickel Towel Bar
My Zircon i520 is not registering any kind of information after I start sliding it across the wall. My son's older model did produce a reading on the same walls. I have plaster over some type of wallboard...
The most common cause of failure in stud finders, with or without wiring detection, is a flat battery!
The lights may still work, the buzzer may still sound but at the end of the day it can take a bit of power to drive the oscillator/sensor circuitry. Replace the battery and try again.
If that doesn't work you may have a faulty unit: return it to the manufacturer because if you depend on it to tell you where live wires are, let alone finding the stud first time, it may cost more than just dollars!
Jul 29, 2010 | Zircon International Stud Sensor Z-Card...
Lost instructions to Ryobi EMTP006 stud finder, I don't remember how to use.
1st press and hold the yellow button on the side until " on " is displayed. THEN after 3 seconds unit calbrated and ready to scan. bar graph and audio indicates edge.
sonic tape
just press read and it will read up to 50ft
"x" button gives area and volume
" " for addiction of length
Jul 13, 2009 | Ryobi WallTech Stud Finder Stud Finders
Stanley 77 500 Intellilaser Pro Stud Sensor & Laser Level Logo
76 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Frank Walton
Level 1 Expert
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
