Question about Altec Lansing VS2121 Computer Speakers
Altec lansing speaker sudden increase and decrease in volume
Anonymous
SOURCE:
Anonymous
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
Anonymous
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
Anonymous
  • 171 Answers
SOURCE: Compaq Presario v2000 ALTEC LANSING speakers not working
Go to "Start", "Control Panel", Administrative Tools, Computer Management, click on "Device Manager" on the left hand side and look on the right hand side. See if you have a yellow exclamation next to the "Sounds, Video and Game Controllers". If yes, double-click on the line with the exclamation and then click on the driver tab at the top. Click update driver and when it asks if you would like to to check the internet for updated drivers, tell it yes, this time only and continue. After this process, it should either download and install a new driver for your sound card or install the one that was shipped with your computer. If this does not work, please let me know and we will check the next possible problem.
Please remember to rate this solution.
Posted on Sep 24, 2008
Vj24601
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
Anonymous
  • 57 Answers
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 22, 2009
After increase volume of Altec lansing T612 voice are break
Also the crossover inside the Altecs must both be controlled.
The diafragms of the tweeters replaced, thats in most cases easy to do selfmade . look for examples on youtube .
What is Clipping Understanding Amplifier Clipping Clipped Signals
Sep 12, 2016 | Altec Lansing Audio Players & Recorders
I am using creative speakers with woofer i get disturbance in audio when increasing and decreasing volume
spray your volume control with a dirt/rust cleaning cannister if you cant access it, open your spk system then spray it directly with straw stick into the cannister so that it can be easily sprayed into that volume control, hope this can help.. thanks for asking, good day..
Nov 14, 2013 | Altec Lansing Audio Players & Recorders
Altec lansing acs45.1 cannot increase volume level by using arrow buttoms on top of cube speaker...sound does come out but a very low levels......have pret
This is a loose connection between PC and the Sub-woofer. The cables may damaged or it may be a hard ware problem.
Think this is helpful !
Aug 11, 2010 | Altec Lansing ACS 45.1 Computer Speakers
Disturbance in audio when i increase d volume
do you have wireless?, this could be affecting your sound, also check your hardware compatability and make sure everything is good 2 go.
Oct 03, 2008 | Altec Lansing Audio Players & Recorders
No sound
see if u can get master speaker wiith cables on it that died on ebay best bet what kinda are these
Jan 05, 2008 | Altec Lansing ACS 45.1 Computer Speakers
Altec Lansing ATP3
there is a lose connection near the main speaker .When i move it sound stops
Dec 17, 2007 | Altec Lansing ATP 3W Computer Speakers
Altec lansing
I had the same problem. After numerous calls to Altec Lansing they sent me out a new one. The new one doesn't have the same connector on it. I called tech support only to hear that they discontinued the 621 and don't make parts for it. Sorry, you are probably out of luck.
Oct 26, 2007 | Altec Lansing 621 Computer Speakers
Can't increase & decrease the volume
Double check your connections. Still not working fine. Remove the input jack connector and try to touch or hold the tip of the connector, also adjust the volume of the speaker, you should heard loudly the 60 hertz sound of your body signal. Otherwise you have a defective amplifier in the speaker system.
Dec 05, 2006 | Dell PART NUMBER KIT SPEAKER MM ACS45...
Altec Lansing VS2121 Computer Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
