Sewing Machines Logo
Question about PfaFF Quilt & Craft Pro 7530
How do I change the needle position on a Pfaff Quilt Expression 4.0
5 Related Answers
Mimito7
Kelley Buchanan
  • 130 Answers
SOURCE: Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Posted on Apr 25, 2009
Ed Paje
  • 632 Answers
SOURCE: I am looking for a service manual for a Pfaff expression 2034
Here is the link for your PFAFF 2030 - 2040. It should be covered in this repair manual.
Posted on Jul 23, 2010
SOURCE: my 2134 is shreading the thread at the last thread
try changing the thread to a different type on a sample piece of fabric
if that doesn't help check the thread guide you mentioned & see if has any burrs on it, burrs can damage thread
Posted on Aug 01, 2010
Anonymous
SOURCE: Just bought a brand new Pfaff Quilt Expression 4.0
this is a known issue with the pfaff.....i have just bought the machine and it has thread uptake issues...thread tension issues and it comes unthreaded by itself often...leaving globs of thread on the bottom stuck in the feed dogs and under the throat plate.....then the stitches are not properly balanced because the tension gets too loose on the bobbin thread....very disappointed to find out it is a known issue with all the viking husqvarna made machines...which are pfaff, janome and viking.....sux.
Posted on Apr 01, 2011
SOURCE: Pfaff 4.0 quilt expression pulling bobbin thread up to top of fabric help.
try a new needle
rethread the machine top & bobbin
try adjusting the top tension just a touch to see if that helps
clean under the needle plate & in the bobbin area for loose threads
or lint
make sure the bobbin is wound correctly & inserted into the bobbin
case correctly
Posted on Jun 05, 2012
1helpful
Pfaff quilt expression 4.2 thread tension issue
Thread tension in this machine is set electronically to vary by type of stitch. There is also an alert light pertaining to the bobbin.
Getting The Quilt Expression 4 2 Ready For The Test Drive
Sewing
The first link also offers a further link to an online guide. That said, as the tension is electronically controlled and if any sort of fine tuning is required, that would likely require a trip to a service center. Hopefully, one of the videos provided by the links above will be helpful
1helpful
Needle hitting bobbin casing on Pfaff Quilt Expression 2046
If you have installed a brand new needle and it is still hitting, then the machine needs an adjustment. Take it for service.
1helpful
2answers
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
NEED A MANUAL FOR PFAFF QUILT EXPRESSION 4.0
Just search the internet for:
Make + Model + the word "Manual"
Pfaff quilt expression 4 0 Manual
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Needles keep breaking when i quilt, its like they dont fit or too long quilt expression 4.0
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
How do you change needle position on a Pfaff quilt expression 4
If you need help finding a manual or with your machine (in USA) please call 1-800-446-2333. 8AM - 4PM CST for support.
1helpful
try a new needle
or lint
case correctly
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
