MobiBLU DAH1500 errors when plugged in with Skylark device found
When I plug in my DAH1500 I keep getting a prompt that my OS WinXP Pro has found a new device and it picks it up as a Skylark II device, it tries to find the drivers, but cannot. Is there anything I can do? I have tried the reset option but no joy.
Is it trashed?
When I plug in my DAH1500 I keep getting a prompt that my OS WinXP Pro has found a new device and it picks it up as a Skylark II device, it tries to find the drivers, but cannot. Is there anything I can do? I have tried the reset option but no joy. When I plug in my DAH1500 I keep getting a prompt that my OS WinXP Pro has found a new device and it picks it up as a Skylark II device, it tries to find the drivers, but cannot. Is there anything I can do? I have tried the reset option but no joy.
You can't post conmments that contain an email address.
I had something similar with my Cube. WinXP pro would detect it a an unknown USB device. Sometimes when I would manipulate the USB cable, it would detect correctly.
To make a long story short, it turned out the be the USB cable. When I tried a different one, everything worked correctly. Hope this helps.
Install first the Win98 OS to your Drive C: and then Install the WinXP to your drive D:
after you restart the system it will prompt you to boot either on Win98 or XP. You can also do this in one hdd only. all you have to do is to repartition the hdd
Good day!That error used to be a non compatible with the hardware.I don't know this board,but i'll based my idea on your trouble..Mostly new hardwares today don't accept XP OS..Try to look the Motherboard's features..see if it is compatible with XP..
Ask me if you still don't get what I mean..
mastergani
MAY BE THIS COULD HELP. PUT YOUR LAPTOP IN FRONT OF A FAN, THEN TRY TO FORMAT IT AGAIN, IT SOUND FUNNY BUT I FACE THIS CASE MORE THEN 3 TIMES, THE LAPTOP JUST TOO HOT DURING THE INSTALLATION (PUT THE FAN WITH LEFT SIDE FACING THE FAN) JUST SHARING=)
the boot has been corrupted... what did u install lately?? i mean before this problem occured... better use the recovery disk or original OS disk and do a system recovery...
IDE AND SATA CONTROLLER PROBLEMS ON MAXTOR DRIVES.UNINSTALL CONTROLLERS AND REBOOT,DO NOT PLUG IDE DRIVE IN.THEN REBOOT AGAIN PLUG IDE DRIVE AND LOOK IN DEVICE MANAGER IF DRIVE IS RECOCNIZED CORRECTLY.(ASUS BOARD) OR INTEL CHIPSET PROBLEMS.
Hey there rcrozier, your solution is to disable ACPI in the BIOS. To do so, follow these steps. 1/ When set up is loading, a blue screen will appear asking if you have RAID devices, indicating pressing F6. Instead press and hold F7. This should prevent ACPI from installing. Alternately at the blue screen mentioned above, press F5 and hold. It should advance eventually to a new screen prompting you to press F2. Keep holding F5. It will give you another screen telling you it cannot recognize your pc type. It gives you two choices: standard pc or other. Choose standard pc. resulting in ACPI not being installed. Unfortunately the other result of this ACPI not being installed is that your power management will be reduced. Overclocking is not advised. Hope this helps. Good Luck!
I had the same problem. I had formatted the player's drive using Windows explorer and the got this error: "File Format error" while trying to play any mp3 file.
I went to the command prompt. Deleted all files:
E:\> del *
Then I copied the MP3 files again in the T.sonic MP3 player. All MP3 files played fine after this.
Typically reremove the usb cable and then uninstall the drivers and any software related to the device ,then reboot the machine and install the driver.Connect the cable only when prompted to or once the installation is complete,THIS SHOULD DTECT THE DEVICE AND YOU WILL BE ABLE TO USE THE SAME.
the plug ins that it relates to can only be other programmes that are associated with the network for example windows zero configuration.
I would suggest going to my computer, right click>properties>hardware tab>device manager and look in the list for network adapters and on the '+' sign right click on your wireless network card and select uninstal.
Restart pc and it should be installed automatically, but keep your eye on the taskbar when it says found new hardware and ensure that it says it has found the intel pro wireless( if thats the model) and try again.
Also re install the drivers from your notebooks web site incase there are updated ones.
cuando lo conecto a mi pc no no lo reconoce por que me faltan los drivers
