Peavey Escort 3000 300 Watt Portable PA Speaker System Logo
A
Anonymous Posted on Sep 07, 2013
Usb show no usable device - Peavey Escort 3000 300 Watt Portable PA Speaker System
Ifixstufff
Level 2:
Champion:
New Friend:
  • Peavey Expert 232 Answers
  • Posted on Sep 20, 2014
Ifixstufff
Peavey Expert
Level 2:
Champion:
New Friend:
Answers
232
Questions
0
Helped
81720
Points
292
Only top layer files are playable, the thing cannot steer through directories. and I think the drive needs to formatted as fat 16.
How can I record my songs to my tablet or my laptop
The best way is to use the USB output from the Fostex. Connect the USB cable from the Fostex to the USB input of the notebook. A Windows computer should show a USB Audio Device in the device manager. If not, you'll have to get a driver from Fostex and install that. But it should just work, it did in my Vista notebook. Then simply get any number of recording software packages (Windows 8 may have a built-in app). I've used Cool Edit and Reason 4 for recording and editing. You should not record the songs using the notebook's microphone input because (1) the analog noise of a recording generated by the notebook's A-D converter is horrible, and (2) you'll have level and impedance matching problems, even after purchasing something like a pair of Bogen WMT1A line matching transformers. Once you've got it recorded, put it in the cloud and download it onto your tablet. I don't think tablets have USB ports, but maybe yours does.
Behringer XENYX 2442 FX: Turntable into CD/tape IN. CD/tape OUT connected to USB device IN. Why is there no signal from mixer to the computer?
If I read correctly, you have outputs on the Behringer (CD/Tape Out) connected to inputs on the Behringer (USB Device In). Is that correct? If so, try going from CD/Tape Out directly to the computer. If not, please explain what the "USB Device In" is.
Thanks,
Rich
Apr 30, 2012 • Music
Zoom h4n won't connect as mic via USB
What I figured out - simple. Plug your usb cable all the way in. That's it. Did I guess it? ;)
Hello,i have a problem with my pa800,my display show:usb enable and os not prezent,turn off and put a os to a stick memory and turn on and push intro1,my display is black 75 procent and 25 work,and i cant...
If you are being asked to reload the OS, you will have to do that. SOME devices have trouble with USB sticks that are larger than some limit... that may or may not be specified. If you haven't tried reloading, try it with a USB stick no greater than 1GB... yes they are getting hard to find that small.
2helpful
I want to transfer some midi files to my Casio LK-230 keyboard. When I plug in the usb cable it does recognize the casio unit but it does not show up on my computer...like there is not unit... How do...
The keyboard will NOT show up on MY COMPUTER as it does not have memory to record and save MIDI files... It will PLAY them real time as the computer sends the data to the keyboard. You can't transfer and save the files IN the keyboard. Some higher level keyboards do have memory and even hard drives... this one does not. This one will have some built in,that you can play but even those you cannot access as if they were memory.
With the USB cable connected, you should be able to see the device listed in the device manager section of the control panel under system hardware.
1helpful
The casio ctk-4000 has an plug and play usb conection but if i huck it up to my laptop(windows7) or computer(windows xp) doesn't there comes anythink poping up in my screen. and if i go to "my...
If it is installled as plug and play you should see it in your devices in the XP system manager and also in the bottom right task bar where other usb devices show. If it shows there, it is installed and you just need a sequancing software to use it
All the channels shows the Clip red light on the Peavey PV6 6 channel mixer and I´m unable to use the device ...Whats is the solution??
It is likely there is a failure of one of the power supply voltages. The solution requires troubleshooting that is NOT DIY unless you are electronically skilled.
1helpful
2answers
Vestax vcm 100 driver traktor pro
hi, you need to go here:
http://help.vestax.co.jp/en/detail.php?id=80&id_page_url=56&cate=0
and download the .tks file for your version of Traktor. Suggest you save it to the Traktor program directory.
Then within Traktor in the controller settings section, load the .tks file, save and you're good to go. Obviously you can tweak the configuration as much as you like once it's loaded. Suggest you always keep a backup of the original.
When I plug the usb cable in to my computer and "open USB," it does not show up as a removable disk. I have used this function on the mkII many times before and this is the first time I have had a...
Hi I had exactly the same problem with my Macintosh, it worked fine until recently but suddenly stopped working. As a matter of fact it is probably due to a compatibility issue of the USB driver after a recent software update of MacOSX drivers. Fortunately I have an old Macbook pro with an old version of MacOSX and the Tascam showed up immediatly and USB worked fine. Therefore, if ou can downgrade your USB driver it might solve the problem.
1helpful
H4 isn't recognised by my Mac as an audio device of any kind. It doesn't even connect properly.
There is a page at http:// www.zoom.co.jp/english/download/software/h4.php that may help you. It is supposed to fix the usb audio interface problem. Hope this helps.
Top Peavey Music Experts
NOEL
NOEL
Ngoro
Are you a Peavey Music Expert? Answer questions, earn points and help others
