Are you referring to the inlet screen on the water fill valve? Screen should not be removed, just cleaned. Screen prevents objects from entering and damaging the valve. This damage may cause an over fill condition.
Hello, it could be a water leak if you have a water dispenser. Behind the
plastic panel in the refrigerator is a plastic water line that make about ten
switch back and forth, and maybe small water reservoir. When push the button to
get cold water it activate a water solenoid on the back of the refrigerator. The
water pressure pushes water through the cooling line. Now, you get a glass of
cold water.
There might be some screw on the panel for removal. There could another
problem it has to do the door seal. The seal has a heater in it and this keep
condensation from build up in your refrigerator. It those darn wigits again. GB
you...stewbison
Order a new line for your model and use the old line to pull it through the door. Cut the head of a screw off and use it to connect the old line to the new water line to help pull it through.
check and make sure that the water fill valve does not have a crak in it usually not enough water in the defrost pan to cause any kind of flooding issue. it is either a bad water valve or a broken water line somewhere on the unit
Your problem is most likely a bad cartridge.#1 turn off water in house #2 remove handle #3 you will see a horseshoe shaped clip that holds in cartridge remove clip and try to pull cartridge straight out you may need to purchase a moen cartridge removal tool for easier removal and install new cartridge and replace horseclip
SHUT OFF ALL ENERGY SOURCES TO HEATER. REMOVE ELECTICAL SUPPLY LINES AND TAPE THEM OFF. DRAIN WATER FROM HEATER. REMOVE AND CAP WATER LINES. TURN OFF LP. REMOVE AND PLUG LP LINE. REMOVE SCREWS FROM OUTSIDE CIRCUMFERENCE OF HEATER. PULL HEATER OUT.
Washers have a fill line to a small blue valve underneath, there is also a power supply, and drain line hose. Make sure to turn breaker and water supply off, before removal
