AEG Lavamat 72640 Front Load Washer Logo
Anonymous Posted on Nov 28, 2017
Lavamat 42260 - E94
Sir,
My washing machine Lavamat 42260 stopped on its cycle and commence to show E 94 on the panel.
I have been told that the PC board needs replacement. If so, can you suggest someone in Malta's region from where I can buy one if it is worthed to repair the washing machine.
Thanks.
biggator
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Feb 02, 2018
biggator
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
3508
Points
20
This is a configuration error. There is a way to reconfigure it, if you have the technical information, but most likely you will need to replace the PC board.
1 Related Answer
Anonymous
  • Posted on Apr 15, 2009
SOURCE: PC board of Lavamat 42260 Top Loader washing
Found that the water heater is giving low insulation resistance. It is being replaced by a new one.
Hello. my Lavamat 74500 update does not start the wash cycle. everythig is on, door locks but nothing happens.
sounds like a water fill problem to me, normally at start of cycle door locked, program set, start water solenoid opens and fills machine with water, once water reaches set level heater will come on and wash program will commence,
so if you have a restriction in the water supply/ water tap not turned on correctly, on blockage in water solenoid valve water flow to machine will be restricted causing a long delay before machine starts, things to try
1. make sure hose connection water valve is fully open
2.open soap draw to see / if you can hear water flowing into machine,
3 if its very slow you have a restriction in water supply
could be a twist in water supply hose, causing a restriction
all above is if machine is taking to long to fill with water,
good luck .
3helpful
2answers
AEG Lavamat 76810 E70 7Beeps Does seem to still work but display shows E70 and 7beeps over and over. Many thanks gary
I Have AEG Lavamat 76810 E70 7 Beeps and Beeps never stops
The water was not hot
I took all the multi-plugs out and put them back in the whole machine ALL CONNECTORS
Now it works fine E70 is gone
3helpful
2answers
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
1helpful
PC board of Lavamat 42260 Top Loader washing machine. (Automatic) Washing Machine stopped on cycle and displayed E94 on panel.
2helpful
Machine was working when at a point it commence to show E94 and stopped functioning.
E94 incorrect configuration of wash cycle.
Could be a job for an engineer. Do you know how to safely drain machine? If so manually drain water from machine, then check the pump, (bottom right front corner) for obstructions. If you have not done this before, proceed with caution. You will need towels to soak up mess.
AEG Lavamat 74800 stops part way through the cycle - Error E50
I suggest trying this link. They will help you online.
https://www.justanswer.com/uk-appliance/23fl9-aeg-lavamat-74800-error-50-reported.html
Lavamat 86800 stop the washing cycle after few seconds without any error code
Hi - did you ever find a solution to the problem? My 12 year machine now showing the same issue.
Top AEG Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
