Here is a hardware test you can run to test the video and lcd screen. That came with your laptop
Diagnostics before windows using the F12 Diagnostics
* Reboot and press F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
during the test it will BEEP ! it is asking you if colored bars are displayed. if the bars look ok then your screen is fine but if during anytime of this test and you see the distortion you described then its the LCD screen or LCD cable
hope that helps
SOURCE: Vertical lines in my laptop screen
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
Hi mikenstacy
Try to connect a normal desktop monitor to the laptop (there will be one vga port where you can connect the monitor) and if you see those lines on external monitor as well then most probably video card has gone bad (you can try to reinstall video drivers in this case) if those lilnes are not there on external monitor then problem is with your LCD so if system is in warranty then get it replaced other wise get in touch with local compter shop and get it replaced.
let me know if this helped
SOURCE: Inspiron 1200 Dead Screen
At first glance, I'd say "bad video/motherboard" ...however, when you hook up an external monitor, you also need to first switch into "external LCD" mode. On the Dell laptop, hit FN and F8 I believe to switch between LCD and external. It will go through several modes...LCD only, external only, neither, and both. Keep switching until you see something on the external.
If you never see output on the external, you've got a video/motherboard problem. If under warranty, contact Dell and place a support call.
If not under warranty, you're looking at anywhere from $200-$400 for a new motherboard, plus labor for someone to install it.
Hope this helps - remember to rate :)
Experience:
- A+ certified technician
- 8 years as IT/manager of a 100% Dell-supplied company, with over 1,500 Dell volume annually
- Dell Level II certified technician
SOURCE: Dell Inspiron 1501 screen half black
Had the same problem. Fixed it though. Here's how:
You'll notice that the screen comes back to life if you press down on the very top of the green line. This is because a controller circuit board behind the LCD screen (at the top) is pressure fit flat-surface-to-flat surface to the contacts on the back of the LCD. Eventually, the sticky substance that holds this circuit board in place wears thin, collects dust, etc.. and the connection between the circuit board and the lcd contact is lost. The line appears where this break in contact has occured.
So, the solution is to increase the pressure at that point to reestablish the connection. I wasn't able to remove the circuit board to clean beneath it as it seemed too likely to cause damage. Nor would I have had the right adhesive to connect it back, so I simply removed the LCD and put a bunch of tape at that point so that it would "push" with a little more pressure when screwed back into place. Worked great.
To remove the LCD, pull off the 6 feet around the screen. Remove the screws behind them. Carefully pry off bezel with a small flathead screwdriver working your way around it. Once removed there are simply 4 screws on the left and 4 more on the right of the LCD to remove. Pull out screen carefully and start stacking bits of tape on the spot where pressure seems to work best. Put it back in and see if you've made any difference. I did this with the computer on so I could verify my results. Just be careful not to short out any naked contacts.
If this doesn't work for you, at least you'll know you just need to replace the LCD, not the video card. Easily found on ebay.
