Question about Renewable Energy
Labeled diagram wind turbine - Renewable Energy
Peter Bochniak
    Problem Solver:
  • 8 Answers
I have built a wind generator and have a schematic in simple terms
Posted on Nov 26, 2014
I have a 400 watt sunforce wind generator that is not spinning a lot and the red light is blinking on it
Check the ball bearings at the axis.when the ball bearings at the axis of the spinning have dust or dirt it turns slow.Clean it or change bearings.
Mar 16, 2015 | Sunforce Products 44444 400 Watt Wind...
Tip
Best Solar Panels, Green Fuels and Wind Turbines for your $
I have been in renewable energy for years and am a co-founder of Nebraska Green Fuels Co-op. (NebraskaGreenFuels.com)
Our partners make the best solar panels, wind turbines, Yellow BioDiesel Mixers, green gasoline fuel and Hydrogen Power cells along with a few other green products.
To get detailed quotes on the items of your needs contact me via [email protected]
on Jun 22, 2010 | Kitchen Appliances - Others
How does a wind turbine work?
A Wind turbine operates on a simple principle .The energy in the wind turns 2 or 3 propellor like blades around a rotor .The rotor is connected to the main shaft which spins a generator to create electricity. Wind turbines are mounted on a tower to capture the most wind energy.
Aug 31, 2014 | Vacuums
Can I buy wind turbine generators on Amazon?
You can buy wind turbine generators from Amazon here:
http://www.amazon.com/s/ref=nb_sb_sabc?url=search-alias%3Daps&pageMinusResults=1&suo=1367394691758#/ref=nb_sb_ss_i_0_14?url=search-alias%3Daps&field-keywords=wind%20turbine%20generator&sprefix=wind+turbine+g%2Caps%2C256&rh=i%3Aaps%2Ck%3Awind%20turbine%20generator&sepatfbtf=true&tc=1367394695955
May 01, 2013 | Renewable Energy
What company is the largest global producer of wind-turbines?
Vestas, a Danish company, is currently the world's leading manufacturer of wind-turbines.
I would like to build a 24volt wind turbine ,I think that I have most of the Items to construct the unit but just need a wiring diagram to get started ,would you be able to help me?
allright. what kind of electric motor do you have? brushed DC or brushless? Yyu will need a controller in both situations. Actually if you have DC type brushed motor you will only need a regulator circuit. You may use one from trucks which is used to charge 24 volt battery:.
Nov 26, 2011 | Cars & Trucks
Need to hook-up pond motor 115V , two speed , 3/4 3450 rpm-1/8 1725 rpm , with switch for speed slection.
We need to know what wires you have as far as connections to the motor AND the switch. I.e. Red white black green and ______?
Is the switch resistive or just a 2 position (high/ low) 15 Amp switch?
We also need to know how the the terminals on the motor board are labeled. i.e T1, L1, T2, L2. T3, T4 etc and ground. L1 Black L2 White for high speed Green for gorund. The other 2 colors will be for the slower speed winding.
Experimenting with electricity can be costly and VERY dangerous. I would do continutiy checks on the motor windings across L1 and L2 or T1 and T2 and the same for the 2nd winding terminals. Then do the same continuity check from the power wires through the switch and verify the winding resistance across the 2 power leads in BOTH switch positions BEFORE applying power.
Most reputable pump manufacturing companies have the winding terminals on the label or included with the pump with a basic wiring diagram.
FYI you can... use a gate valve for controlling output flow from the pump and run the pump at one speed as an alternative.
I am just being honest here.. without either a wiring diagram of your pump and switch assy it is difficult to pass "safe and sound" advice to you.
Thanks for using FixYa.
Kelly
Apr 06, 2010 | Garden
Wind turbine plans/solar panel plans
You are in for a lot of fun and money saving tips and instruction. I as you am interested in building a wind turbine/ generator to do my part in saving the environment and saving me money. I have a small work -shop and have some generator parts to work with. Reading about building is fun but watching a video of actual working machines is the most. Go to www.youtube.com and enter homemade wind generator in the search box and enjoy the fun and instruction. Good luck with you project.
Jan 30, 2009 | Electrical Supplies
Coleman 5000 w generator
1) You'd have to figure out a way to support the engine end of the rotor. Right now the engine rear main bearing is the front bearing of the generator.
2) You'd need to make a wind turbine that produces 6+ horsepower (at least) to get the 5 Kw out of it.
Usually small wind turbines drive polyphase generators that charge batteries used to run inverters. Go see: http://www.otherpower.com/otherpower_wind.html for a pretty good discussion of the problems to solve.
Oct 25, 2008 | Coleman Powermate Premium Plus 6250W...
Renewable Energy Logo
1,184 people viewed this question
Top Renewable Energy Experts
Greg Scott
Greg Scott
Lukas Alexander
Level 1 Expert
Are you a Renewable Energy Expert? Answer questions, earn points and help others
