Vizio GV47LF Television Logo
Craig Rice Posted on Sep 07, 2013
No Picture on Vizio VT420M TV. Only Sound. Any Ideas how to fix it myself ?
VizioBrazil
Level 1:
New Friend:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Nov 25, 2013
VizioBrazil
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
2082
Points
I had a similar problem a while ago! I checked up some threads around the web and it was when i found out a tip about replacing the inverter board pannels of the backlight!! guess what ? It worked for me... My Vizio HDTV is about 5 years old so far and it is up and running like a champ...!! I hope it works for you!
5 Related Answers
Anonymous
  • Posted on Aug 11, 2008
SOURCE: VIZIO 50" PLASMA
Wow. This is more comon than I thought. My 50" Vizio plasma just went out as will after a loud pop noise. Power button is still lit. Sound continue to come through but no picture. I will dig into it and see if I can find a appropriate solution.
B52Tony
Tony Nguyen
  • 96 Answers
  • Posted on May 20, 2009
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Anonymous
  • Posted on Jul 27, 2009
SOURCE: Sound but no picture on Vizio WS42L TV
did you ever get it resolve? I am having the same problem. my tv is a year and and 1 week old. I am so upset.
Raditronic
Radames Pagan
  • 196 Answers
  • Posted on Apr 30, 2010
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Anonymous
  • 18 Answers
  • Posted on Mar 01, 2011
SOURCE: I've owned a Vizio VT420M for just over 13 months.
The flickering is most likely due to a faulty fluorescent backlight. Once the bulb heats up the flickering usually goes away. Some bulbs are easier to replace than others so I would contact your local TV repair shop.
My vizio model# E480-B2 was working fine one day and the next when I turned it on I have no picture.. Perfect sound ! Does anyone have any ideas?
Hi , The link below is a YouTube page full of videos showing how to fix a Vizio television NO picture GOOD sound, I hope this helps....... CHEERS..
Vizio Tv With No Picture Good Sound YouTube
2helpful
VT420M no sound or picture and turns off by itself
this sounds like a main board failure but a defective power supply can mimic some symptoms of a bad main board. I would recommend you get a diagnosis done on the set. If I was a betting man, I'd guess the main board
Service manual
Send your email address to me by Fixya comment, and get a copy of the service manual by return mail.
Vizio vt420m comes on then flickers and then doesn't show any picture, but the tv stays on
If you have not been using the TV for quite sometime, moisture would have developed some defects inside the TV when you switched on. Sometimes even insects and lizards might get in and cause short circuits. Anyhow this might require attention by a qualified service technician.
I have a Vizio VT420M. When I turn it on by remote, or power button, the Vizio light changes from amber to white, but I get no picture at all OR sound. Do these symptoms sound like a bad power supply,
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
No picture just sound
As of April 7, 2011 Vizparts.com has new shipment of main board #CBPF9D1KZ4 for $250.00 with a $50 core value, and 14 business days to return if not the problem. Also check Ebay search
I've owned a Vizio VT420M for just over 13 months. About a week ago the tv started flickering when I turn it on. The picture is visable, but the area around the actors is flickering. After about 7 to 10...
1helpful
My Vizio VT420M LCD TV has for several months has changed to a dark screen while viewing without any other problems. We always hit "power/cable" on the HD cable box and it would immediately come...
Now the tv u turn on u have a flashes of a picture only few sec. and died have sound left only?Yes,than the 2 long boards call the LCD inverter boards are the causes and the problems.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter board for the replacement.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
