It sounds like one of two things. Either there is a short circuit in your camera that is draining the battery or the camera's battery charger circuit is not charging the battery. There are a few things you can do. You can send the camera to Nikon USA for repair (look on the Nikon website for the address the closest repair center). The other thing you could do is buy an inexpensive external charger for the battery and see if the camera works for a resonable period after charging the batteries externally. Adorama.com carries both the Nikon and off brand models and will give you the best price. It that works, you know that the camera's battery charging circuit is the problem. If that is the case, you could pass on repairing the camera and just use the external charger. If that does not solve the problem, the camera will need to be repaired.
SOURCE: Batteries die
Hello; Same as tbeartusk on my coolpix L3 Nikon
Batts exhausted within 30 Min. and screen says Batteries "exhausted"
SOURCE: Can I charge Coolpix S210 via USB cable and wall outlet?
No. In order to keep down the size and weight, the camera does not include the circuitry needed to charge the battery.
SOURCE: Hi my Nikon s6000 coolpix
Hello
OK, here is a suggestion, no guarantees, if this does not work, let me know so we can try something else.
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful. Please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
SOURCE: My camera will not charge. It was purchased just
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
Did you ever find a solution for this? I'm having the same problem.
